Go to Post We're somewhere in the range of ludicrous speed to bench grinder. - Ginger Power [more]
Unread 03-02-2010, 20:46
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Motors allowed on the robot.
Originally Posted by joek View Post
well.... are they ever gonna check if you removed the potentiometer, they don't have time to disassemble every last servo
<R54> So that the maximum power level of every ROBOT is the same, motors and servos used on the ROBOT shall not be modified in any way , except as follows:
A. The mounting brackets and/or output shaft/interface of the motors may be modified to facilitate the physical connection of the motor to the ROBOT and actuated part.
B. The gearboxes for the Fisher-Price motors are not considered “integral” and may be separated from the motors.
C. The electrical input leads on the motors may be trimmed to length as necessary.
Are Lights Allowed on the Robot?? team 2191 Electrical 5 14-02-2008 18:00
Are Lights Allowed on the Robot?? team 2191 Technical Discussion 5 14-02-2008 18:00
What is the maximum Number of motors allowed? borabora Motors 6 10-01-2008 16:54
Are all banebots motors allowed? EnderWiggin Motors 7 11-01-2007 22:27
How many motors allowed? holyrollers Motors 3 06-02-2006 22:38
