Re: [FTC]: Robot problems with motor movment
Can you post the code that you're using?
Tom and Mike,
Are you using the feedback from the motor? It is possible that the code is written in such a way that it runs that way. |
Tom and Mike,
Assuming that you are using the competition templates, this could be a problem with your initialization (running in one direction) versus your main loop (reversing direction). Exact cause could be different depending on your programming language choice. I agree that posting your code is the fastest way for people to help. You should also be sure that you have the correct firmware installed in your NXT brick and that the latest templates were used. Regards, Mike |
It will also be helpful to note exactly when this occurs. At the beginning of Autonomous, at the beginning of Teleop after Auto or in Teleop only mode?
| [FTC]: [FTC]: Motor Problems | fqzeng | FIRST Tech Challenge | 3 | 16-02-2009 19:12 |
| [FTC]: Problems with Motor Encoders? | FTC 2891 | FIRST Tech Challenge | 2 | 16-02-2009 19:03 |
| [FTC]: Random Error with FTC motor control | Xaphiinia | FIRST Tech Challenge | 2 | 01-12-2008 15:39 |
| [FTC]: FTC Servo-Motor Problem with Labview | dnhansen | FIRST Tech Challenge | 1 | 26-10-2008 00:43 |
| [FTC]: [FTC] Motor Controller problems | michael714 | FIRST Tech Challenge | 4 | 14-10-2008 00:33 |
