Go to Post The only odd part about this competition is that rather than further convince me that I want to be an engineer, it did the converse... I want to be a teacher. - pauluffel [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 19-01-2010, 18:11
davidalln's Avatar
davidalln davidalln is offline
World's Worst Coder
AKA: David Allen
FRC #2415 (The Westminster Wiredcats)
davidalln is on a distinguished road
Send a message via AIM to davidalln
Re: ofstream (standard C++ file output) not working
Did you or anyone else successfully get a log running on their cRio? We are trying to do something similar, and we have had consistent success with creating the file but very spotty success when writing to it (depending on where the lines are added in the code). Sometimes it works sometimes it doesn't.
SANTOSH ANDREW DECKER RICK WYNNIE SEAN DEREK MATT
(alamo (semis), p'tree (CHAMPS!), nc (CHAMPS!), newton (quarters))
Best four years of my life. Thanks to everyone who made it happen.
Unread 25-01-2010, 14:37
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
I know this is quite a bump, but now I'm even having problems using C file I/O with FILE* pointers. I've called Priv_SetWriteAllowed(1) and still weird stuff happens. Sometimes things work fine, but there's a boat load of issues most of the time:
  • While some files write fine, others don't write at all, and still others write nothing but whitespace.
  • fwrite() reformats strings for some bizarre reason. Example: I wanted to print some formatted data into a .csv (comma seperated value) file. I used sprintf() to print some floats with some commas, carraige returns, and line feeds. Calling printf() on the string created with sprintf() yields what I would expect, but when I write the exact same string to the file with fwrite(), every float is smaller by two orders of magnitude.
Does anybody have any idea what could be causing this? It's making things very difficult and I can't imagine why it would be happening.
Unread 25-01-2010, 22:16
TheDominis TheDominis is offline
FRC #2152
TheDominis has a spectacular aura aboutTheDominis has a spectacular aura about
I've found that some parts of the STL do not work with well/at all Wind River. I tried to use std::fstream to store some packet data, but had to use c-style file I/O for it to work.
Unread 26-01-2010, 00:15
slavik262's Avatar
AKA: Matt Kline
C-style file I/O isn't working for me at all either...
Unread 26-01-2010, 13:35
FRC #2152
Interesting. What permissions are you using? I used "w".
Unread 26-01-2010, 16:37
slavik262's Avatar
AKA: Matt Kline
I was using w. I guess I could try wb or w+, but I was just writing text...
Unread 31-01-2010, 19:57
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
I (finally!) got a chance to test this again.
code (in auto)
ofstream txt;
txt.open("test.txt");
txt<<"IT WORKS!!!"<<endl;
for some reason, (without the priv_setwrite stuff) it worked 2 of the three times i tested it. No difference except different flies
Watchdog.Kill();
Unread 01-02-2010, 10:04
slavik262's Avatar
AKA: Matt Kline
Exactly! That's what's so odd about it. It's not even that it doesn't work, but that it works inconsistantly with no changes except filenames. I have no idea what could be causing the problem. It's so frustrating.
On the note of standard library things failing, does anyone have issues with std::cout? printf() works fine, but cout refuses to print a thing. I'm using the VxWorks Target Console in WindRiver.
Unread 01-02-2010, 15:10
byteit101's Avatar
cout is mis-directed most of the time (strange), but cerr is working fine for us. we rdbuf it though,
streambuf *cerbuf=cerr.rdbuf();
cout.rdbuf(cerbuf);
EDIT: now that I think about it, the getting started guided called it printf/cout output. strange they did not get it working with that title
Watchdog.Kill();
Unread 02-02-2010, 18:10
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
This is a known issue with the Target Console. cout does not work, but printf does. If you are using the Serial console, I believe the cout will work. Probably with NetConsole as well, but I haven't tried it. I tend to completely avoid things that work "in certain cases".
It never bothered me, though since I like to format the things I print and inserting magic format objects feels like a lame hack compared to a concise format string. Oh well... preferences, I guess.
-Joe
Unread 02-02-2010, 18:14
Originally Posted by byteit101 View Post
...for some reason, (without the priv_setwrite stuff) it worked 2 of the three times i tested it. No difference except different flies
This sounds like a race condition to me. I know there are several files in the vision code (and probably others) that call Priv_SetWriteFileAllowed in some cases. Perhaps in the test runs where it works, that code happened to win the race against your test code.
-Joe
Unread 03-02-2010, 08:37
slavik262's Avatar
AKA: Matt Kline
I agree that behavior like this sounds like a race condition, but why would a race occur for a file stream, especially to a file that's not used by any other part of the system?
Unread 03-02-2010, 15:11
I was under the impression that Priv_SetWriteFileAllowed was a global system setting, not associated with any particular task or file handle. If the fopen is racing with Priv_SetWriteFileAllowed, it doesn't matter who is calling each of them.
-Joe
Unread 03-02-2010, 18:06
slavik262's Avatar
AKA: Matt Kline
-Joe
From my understanding, you call Priv_SetWriteFileAllowed(1) to allow a file write operation and then call fopen() as usual.
Unread 04-02-2010, 02:25
Yes... and...
The way I understand it, it enables write access to the filesystem as a whole. In other words, if no one calls it, noone can write to the disk. If anyone calls it, then anyone can write to the disk (or open for write).
p2 not working? Lone_Wolf92c Programming 5 22-02-2008 08:49
IR Board Not Working (But NOT Fried) itsme Electrical 2 18-02-2008 06:11
Beware - transmission output shaft is not 5/8"! jskene Kit & Additional Hardware 30 13-02-2006 14:01
Drive() Not a Standard Toolset in EasyC? Chris_Elston Programming 3 08-02-2006 09:01
Beware - transmission output shaft is not 5/8"! jskene Technical Discussion 3 19-01-2006 14:24
