#121
Re: Fasteners extending outside the FRAME PERIMETER
I can't help but wonder how this will really be checked and enforced at the competitions (especially for really small protrusions like rivets...)
#122
A mentor and RWFA winner says that the rule is "stupid". If the robot has bolt heads (or whatever) that protrude from the frame perimeter hold the bumper off of the frame, small holes can be drilled to "encourage a tight, robust connection between the BUMPERS and the FRAME PERIMETER".This makes so much sense and last year they finally got it right. NOW...... From the update: Note: to permit a simplified definition of the FRAME PERIMETER and encourage a tight, robust connection between the BUMPERS and the FRAME PERIMETER, minor protrusions such as bolt heads, fastener ends, rivets, etc are excluded from the determination of the FRAME PERIMETER. So bolt heads are not part of the perimeter except that the robot perimeter has to fit flush against the wall. I don't understand now for sure. |
#124
Suppose I have a cube bot, perfectly flat sides of whatever dimension, is this robot legal (assuming I put bumpers on it at the right height and it is within the size limits, etc...)? I had assumed yes, but now I think no because the entire robot side will hit the wall. Wait, no, this doesn't say anything about the bumper zone only hitting the the wall, just the FRAME PERIMETER. But wait didn't the definition of the FRAME PERIMETER include the BUMPER ZONE... FRAME PERIMETER – the polygon defined by the outer-most set of exterior vertices on the ROBOT (without the BUMPERS attached) that are within the BUMPER ZONEYes, it does.... But then, that push against the wall bit was in a blue box so perhaps it doesn't really apply... ...except there is another blue box that says something about No Mushroom bots -- which is crazy because, to me, a short robot with the FRAME PERIMETER extending out beyond the edges of the lower robot is almost exactly what I would think of when you say "Mushroom bot" but it is in a rule saying that this is NOT what you want... ....I am totally confused. It is late, I will see things clearly in the morning. Joe J. Last edited by Joe Johnson : 04-02-2010 at 09:15. |
#125
They want a mushroom bot, except they don't... The thing is, the mushroom pileus (cap) HAS to be the frame perimeter, not something above. Either way, you have a mushroom bot, only one of them being legal. Anyway, that fungal reference is in a blue warning box and, as stated at the top of the manual, they don't have the weight of a rule and, whenever contradicting a rule, are void.
| kicker extending outside of robot | caincteam2777 | Technical Discussion | 5 | 17-01-2010 22:42 |
| Frame Perimeter x Bumpers | sloteera | Rules/Strategy | 8 | 14-01-2010 11:18 |
| Frame Perimeter? | jimbot | General Forum | 2 | 10-01-2010 13:48 |
| Holding of Game-Pieces Outside the Robot Perimeter | MikePres | General Forum | 2 | 24-01-2009 07:21 |
| Ramps extending outside of the home zone | Shomron1690 | Rules/Strategy | 31 | 20-03-2007 13:49 |
