Go to Post Please don't confuse energetic enthusaism with acting obnoxious. - Alan Anderson [more]
  #121   Spotlight this post!
Unread 03-02-2010, 19:46
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
Re: Fasteners extending outside the FRAME PERIMETER
I can't help but wonder how this will really be checked and enforced at the competitions (especially for really small protrusions like rivets...)
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
  #122   Spotlight this post!
Unread 03-02-2010, 21:11
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Originally Posted by Paul Copioli View Post
P.S. - JVN says 148 will be bringing lots of extra shim strips with us to Dallas and Houston. 217 will be bringing the same to Finger Lakes, Cass Tech, and Troy. There will be many teams that are totally blind sided by this because they do not have as much "common sense" as some people on CD and they don't check CD.
Thanks for the idea Paul. I will try to make sure our team does the same for teams up here in MN.
  #123   Spotlight this post!
Unread 03-02-2010, 22:21
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
As it says in the explanation, if they push the robot against a wall, only the frame perimeter would touch the wall. If you run your hand down the side of the robot and feel a bump then you violate the rule.
A mentor and RWFA winner says that the rule is "stupid". If the robot has bolt heads (or whatever) that protrude from the frame perimeter hold the bumper off of the frame, small holes can be drilled to "encourage a tight, robust connection between the BUMPERS and the FRAME PERIMETER".This makes so much sense and last year they finally got it right. NOW......
From the update:
Note: to permit a simplified definition of the FRAME PERIMETER and encourage a tight, robust connection between the BUMPERS and the FRAME PERIMETER, minor protrusions such as bolt heads, fastener ends, rivets, etc are excluded from the determination of the FRAME PERIMETER.
So bolt heads are not part of the perimeter except that the robot perimeter has to fit flush against the wall. I don't understand now for sure.
We do not stop playing because we grow old;
we grow old because we stop playing.
  #124   Spotlight this post!
Unread 04-02-2010, 00:09
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
<snip>
I am getting old, but I just now really read that bit about the wall. I know I read it 10 times but I didn't READ it.
Suppose I have a cube bot, perfectly flat sides of whatever dimension, is this robot legal (assuming I put bumpers on it at the right height and it is within the size limits, etc...)?
I had assumed yes, but now I think no because the entire robot side will hit the wall.
Wait, no, this doesn't say anything about the bumper zone only hitting the the wall, just the FRAME PERIMETER. But wait didn't the definition of the FRAME PERIMETER include the BUMPER ZONE...
FRAME PERIMETER – the polygon defined by the outer-most set of exterior vertices on the ROBOT (without the BUMPERS attached) that are within the BUMPER ZONE
Yes, it does.... But then, that push against the wall bit was in a blue box so perhaps it doesn't really apply... ...except there is another blue box that says something about No Mushroom bots -- which is crazy because, to me, a short robot with the FRAME PERIMETER extending out beyond the edges of the lower robot is almost exactly what I would think of when you say "Mushroom bot" but it is in a rule saying that this is NOT what you want...
....I am totally confused.
It is late, I will see things clearly in the morning.
Joe J.
Team #88, TJ2
  #125   Spotlight this post!
Unread 04-02-2010, 02:50
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Originally Posted by Joe Johnson View Post
except there is another blue box tha says something about No Mushroom bots -- which is crazy because to me a short robot with the FRAME PERIMETER extending out beyond the edges of the lower robot is almost exactly what I would think of when you say "Mushroom bot" but it is in a rule saying that this is NOT what you want...
Glad I'm not the only one confused. All along, I had no idea what they meant by "no mushroom bots", and yes, to me it seems this is exactly what you would want in order to satisfy the rule. Does FIRST know about some rare inverted mushroom that I do not?
  #126   Spotlight this post!
Unread 04-02-2010, 07:17
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Yes, it does.... But then, that push against the wall bit was in a blue box so perhaps it doesn't really apply... ...except there is another blue box tha says something about No Mushroom bots -- which is crazy because to me a short robot with the FRAME PERIMETER extending out beyond the edges of the lower robot is almost exactly what I would think of when you say "Mushroom bot" but it is in a rule saying that this is NOT what you want...
Joe J.
Perhaps the GDC is taking a lesson from the ancient Chinese. Inscrutability lends the impression of wisdom, and disguises folly.
Former Mentor Team 1771
Former mentor Team 4509
  #127   Spotlight this post!
Unread 04-02-2010, 07:53
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
They want a mushroom bot, except they don't... The thing is, the mushroom pileus (cap) HAS to be the frame perimeter, not something above. Either way, you have a mushroom bot, only one of them being legal. Anyway, that fungal reference is in a blue warning box and, as stated at the top of the manual, they don't have the weight of a rule and, whenever contradicting a rule, are void.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
kicker extending outside of robot caincteam2777 Technical Discussion 5 17-01-2010 22:42
Frame Perimeter x Bumpers sloteera Rules/Strategy 8 14-01-2010 11:18
Frame Perimeter? jimbot General Forum 2 10-01-2010 13:48
Holding of Game-Pieces Outside the Robot Perimeter MikePres General Forum 2 24-01-2009 07:21
Ramps extending outside of the home zone Shomron1690 Rules/Strategy 31 20-03-2007 13:49
