Go to Post Our Digital Sidecar can attract metal chips from distant planets. - electroken [more]
Go Back   Chief Delphi > Technical > CAD
Unread 25-09-2009, 13:25
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
CAM Software - Free?
Since our team may start milling more things I was looking for CAM software (unfortunately I do not know if our mill can use the files but it would be simpler for the EWCP if we could do it ourselves as well as I wan to learn it)
It appears Pro/E has built in CAM features, however I really like Solidworks, is it possible to take a part which has triangular filleted cutouts for example, open it in Pro/E intact and CAM it?
Are there any other solutions provided to FRC for the CAMing of Solidworks Files? Or should I acquire Pro/E (which I to some degree want to try also.)
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 29-09-2009, 08:58
Cmorse Cmorse is offline
Cmorse is an unknown quantity at this point
Re: CAM Software - Free?
Trent,
I've run this question past my technical people at SolidWorks and here is the response:
I would suggest that you turn to CamWorks, SolidCAM, HSMWorks, MasterCAM who provide a CAM solution. They are focused on CAM first and foremost. If you are looking for a solution for the mill, then any one of those partners should be able to write the appropriate gcode.
With respect to the question at hand, I do not see a reason why Pro/E would not be able to import any model that was developed in SolidWorks. At worst, you would need to export the file to an appropriate file format for Pro/E to import.
The partners that I recommend above all have an AddIn solution to operate within SW.
Unread 29-09-2009, 16:31
College Mentor
AKA: Trent Borman
Ok, unfortunately I don't think any of those companies sponsor FIRST which could make acquiring the software more difficult, maybe I will contact them and see what they have to say. Having a integrated solution would be nice.
Thanks for the help,
Trent
Unread 29-09-2009, 17:57
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Trent
CamWorks will sell you a $100 educational license that is good for a year. We purchased a few seats 2 years ago, hoping the integration with Solidworks would prove more efficient than what we currently use, but that turned out to not be the case for us.
2001-2004: Team 100
2006-Present: Team 254
Unread 22-12-2009, 22:56
Passion Passion is offline
Jim Zhou
FRC #2198
Passion has a spectacular aura aboutPassion has a spectacular aura aboutPassion has a spectacular aura about
Excuse my ignorance, what are CAM software and what does it do. This is not the first time I`ve seen this word CAM, which makes me wonder alot whenever I see it.
Unread 22-12-2009, 23:13
REVving up for a new season
FRC #2848 (All-sparks)
CAM is Computer aided Manufacturing and it is the first step between Designing something in CAD and taking the part off the CNC machine. It allows you to tell your machine how a part is fixtures, what size/type of cutting tool you are using, the constraints of the machine and it will generate a tool path to cut the part. For the most part it is not a hard of a process to do once you have the software setup for your machine.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 23-12-2009, 20:59
DonRotolo's Avatar
Back to humble
FRC #0832
CAD = Computer-Aided Design
CAM = Computer-Aided Manufacturing (or Machining)
CNC = Computer Numerical Control (Meaning something controlled by a computer).
You design it in CAD and make it using CAM to control a CNC machine (mill, lathe, whatever). Often you use CAM to create a file of "G-Code", which is then interpreted by the CNC to actually produce the part. G-Code is a standard, there are others. Google it.
Unread 31-12-2009, 03:52
Adam.garcia Adam.garcia is offline
Design Mentor
FRC #0004 (Team 4 Element)
Adam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really nice
Hello,
I am currently head of machining and work a lot on the CNC. I use gibbsCAM for all of my cnc purposes (Milling and Lathe) and it works great. Our team has gotten ten seats to the latest version of gibbsCAM. All you have to do is call them up and they are more than happy to assist you in the instillation as well as beginning usage. Just mention that you are a FIRST robotics team.
If you have any more questions, feel free to ask.
Thanks,
Adam
Team 4 Element
Unread 31-12-2009, 04:00
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Originally Posted by Adam.garcia View Post
Hello,
Thanks,
Adam
Team 4 Element
Do they give out free seats?
-RC
R.C.
MadTown Robotics Team 1323
Unread 04-02-2010, 08:56
skotmorris's Avatar
skotmorris skotmorris is offline
Windchill Product Manager
FRC #4909 (Bionics - Billerica Memorial High School)
skotmorris is an unknown quantity at this point
Hi, the current Schools Edition of Pro/ENGINEER includes our Expert Machinist CAM solution! If you have downloaded the latest version, M092, you already have a great CAM solution to get started with.
