Go to Post the usual Canadian thing - Karthik [more]
Unread 04-02-2010, 09:02
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Re: NEED HELP WITH SERVOS!!
You need to put some math in between your joystick button outputs, and the Servo Set Angle block.
That SetAngle SubVI is expecting a number between 0 and 180 degrees(typically), and not the simple true/false (boolean) that you're trying to connect in your 3rd image.
How do you want the button(s) to steer it? If you are controlling both the PAN and TILT motors, then you'd need at least 4 buttons to steer it left/right or up/down. Here's one idea, read the angles from the servos, then use some true/false statements from the buttons to either add or subtract some constant value (like 10 degrees) to the read angles, then set that new angle value into the motors. If none of the 4 buttons are pressed, simply pass the original value (Get Angle) to the new value (Set Angle).
There are many many options to do this ... this is just one ... tell us more about your intent ...
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Labview Servo Control Issue EricWilliams Programming 5 22-01-2010 14:24
Camera servo control off of the Joystick axes m3rc1l3ss NI LabVIEW 5 13-03-2009 20:00
Servo Control? mattg101 Technical Discussion 2 20-01-2007 13:12
Direct control of a Servo or Speed Controller Schmitty! National Instruments LabVIEW and Data Acquisition 3 06-03-2006 13:53
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
