Go to Post "The lowly snowflake is very fragile, but look at what they can do when they stick together" - Wayne Doenges [more]
Unread 04-02-2010, 08:51
WIllowSquID WIllowSquID is offline
FRC #1877
WIllowSquID is an unknown quantity at this point
grappling hook
What is the legality for projectiles during the final portion of the round, specifically a grappling hook to be able to get to the tower?
Unread 04-02-2010, 08:58
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Re: grappling hook
They're technically legal, but if you miss and it hits the floor or it extends outside your size constraints you will be penalized.
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 04-02-2010, 09:23
FRC #1877
Re: grappling hook
thank you very much
Unread 04-02-2010, 09:27
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Re: grappling hook
wait why would you be penilized for hiting the floor?
Every day is a new adventure!!!
Unread 04-02-2010, 09:35
cbeavers6790's Avatar
cbeavers6790 cbeavers6790 is offline
AKA: carroll
FRC #3542 (Team S.P.E.E.D)
cbeavers6790 will become famous soon enough
Re: grappling hook
You would only be pentalized if it hit the floor and went outside the 84 inch diameter circle that your robot can expand to in the finale. as long as your grappling hook stays inside the circle you are fine, but if your robot is short then your grappling hook may need to extend farther and go outside the circle the finale dimensions are 7 and1/2 ft tall and an 84 inch diameter circle as stated in section 8 of the rule book. Hopefully this helps you.
IM THE ENFORCER OF ALL RULES (at least the ones in the manual)
Unread 04-02-2010, 09:39
lbarger's Avatar
lbarger lbarger is offline
Senior LRI NC District
AKA: Lee Barger
FRC #0587 (The Hedgehogs)
lbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud of
Re: grappling hook
You could be penalized if the hook causes damage upon hitting the floor, bump or other field element.
Unread 04-02-2010, 09:41
the man's Avatar
AKA: Jacob Overla
FRC #4004
Re: grappling hook
Hey if it weights that much im more concerned at what it would to if it hit my robot.
Unread 04-02-2010, 09:43
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: grappling hook
You would also have to avoid the ball return rails. Might be hard to do.
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
Re: grappling hook
Which would also bring up entanglement issues.
Unread 04-02-2010, 09:46
the man's Avatar
AKA: Jacob Overla
FRC #4004
Re: grappling hook
Ya thats a good one i didnt think of that some one riping out my crio with a grappling hook not the way i want to end a mach.
Unread 04-02-2010, 09:48
thatoneguy23's Avatar
thatoneguy23 thatoneguy23 is offline
Fiding everything we need to know.
FRC #2389 (Oklahoma STORM)
Team Role: Scout
thatoneguy23 is on a distinguished road
Re: grappling hook
There is also the issue that it might be considered "unsafe"...
so i don't know if it could be legal.
I think, therefore I am lost....- Me
"The difference between me and the rest of the world is sanity. They have it, I don't"
Unread 04-02-2010, 09:49
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
Re: grappling hook
The hook may also become a traction device once it hits the ground. Metal on the ground is illegal per <R08>
<R08> ROBOT wheels, tracks, and other parts intended to provide traction on the FIELD may be purchased or fabricated (“traction devices” include all parts of the ROBOT that are designed to transmit any propulsive and/or braking forces between the ROBOT and the FIELD). In no case will traction devices that damage the carpet or other playing surfaces be permitted. Traction devices shall not have surface features such as metal, sandpaper, hard plastic studs, cleats, or other attachments. Anchors (i.e. devices that are deployed/used to keep one’s ROBOT in one place and prevent if from being moved by another ROBOT) shall not use metal in contact with the carpet to “stay put.” Gaining traction by using adhesives or Velcro-like fastener material is not allowed.
Unread 04-02-2010, 09:50
the man's Avatar
AKA: Jacob Overla
FRC #4004
Re: grappling hook
What if its covered in a rubber coating?
Unread 04-02-2010, 09:58
Chains=Fun
Re: grappling hook
<R05> Exterior or exposed surfaces on the ROBOT shall not present undue hazards to the team members, event staff or GAME PIECES. Reasonable efforts must be taken to remove, mitigate, or shield any sharp edges, pinch points, entanglement hazards, projectiles, extreme visual/audio emitters, etc. from the exterior of the ROBOT. All points and corners that would be commonly expected to contact a Game Piece should have a minimum radius of 0.125 inches to avoid becoming a snag/puncture hazard. All edges that would be commonly expected to contact a Game Piece should have a minimum radius of 0.030 inches. All of these potential hazards will be carefully inspected.
It would appear based on <R05> that any projectile would be illegal, however I would recommend asking Q&A to clarify.
Unread 04-02-2010, 11:48
GaryVoshol's Avatar
Cogito ergo arbitro
Re: grappling hook
As discussed in these other threads
http://www.chiefdelphi.com/forums/sh...grappling+hook
there is substantial risk of exceeding your 90" maximum height if you're aiming for a bar 84" off the ground.
Closing ...
(since 2004)
Using a grappling hook to climb the tower Team 2811 Rules/Strategy 12 10-02-2010 17:00
Grappling hook? Sean Raia Technical Discussion 27 27-01-2010 20:18
Special grappling hooks for throwers? ShadowNinja General Forum 3 04-01-2009 17:48
Hook edomus General Forum 2 23-02-2004 19:00
Batttery hook up piconysm Technical Discussion 3 17-01-2002 18:21
