Go to Post A pole is usually made of aluminum or steel pipe. You can get these wherever you get metal. :) As for polls, there's a check box in the "Additional Options" section of the New Thread page that you can click to create said poll. - Chris is me [more]
Unread 03-02-2010, 13:15
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: Reasoning of the GDC
Originally Posted by Jones571 View Post
in 08 they did not limit cV but only limited you to the ones provided in the current KOP or previous years.
As we have found the old festo block has a Cv of .3 so it is good. So are you saying the SMC valve of 2008 had a .4 Cv? and if so were did you get this information from.
Don't make a statement unless you are sure of your facts. I always check my facts before I post.
from the 2008 rule book:
<R88> There is no limit to the number of solenoid valves, pressure regulators, pressure gauges,
and connecting fittings that may be used on the ROBOT. All such devices must be “off the
shelf” pneumatic devices rated by their manufacturers for pressure of at least 125psi.
We used a manifold with 4 SMC valves rated at .4 Cv.
Former Mentor Team 1771
Former mentor Team 4509
Unread 03-02-2010, 13:55
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
And R87 2008 is were I took my statement of solenoids are allowed from 08 kop and older so how are my facts not checked? I read the entire pneumatics section not just the rule that if taken out of context helps me.
R87 IMHO says all solenoids needed to currently or previously offered in a KOP. R88 would clarify this even further that it must be COTS so you can't use something that would be discountinued and you can have as many as you would like on your robot.
So if the SMC you used was never in a KOP it should of never been a ROBOT PART to begin with.
Unread 03-02-2010, 15:05
martin417's Avatar
AKA: Martin Wilson
Again, opinions are just that. We had the same concern in 2008, and asked and received the following on Q&A:
Pneumatic System
Pneumatic valves
Pneumatic valves
Posted by FRC1771 at 01/18/2008 09:18:14 am
Rules <R86> and <R87> seem to limit the pneumatic valves to the ones in the KOP (from this
or previous years). However, rule <R88> appears to allow any solenoid valve, regulator,
gauge, or fitting, as long as they are off the shelf, and and rated for at least 125 PSI.
My question is: can we use other valves and fittings than those supplied in the kit. Specifically,
Valves with larger Cv than the ones in the kit, and other one touch fittings such as muliti-T's
Page 172 of 223
2008 Q&A Forum Export
generated: 02/27/2008 09:27:01 am EST
etc.
Re: Pneumatic valves
Posted by GDC at 01/21/2008 12:32:44 pm
Rule <R88> specifically permits the use of additional (not-Kit Of Parts) solenoid valves and
fittings. Valves with a larger internal Cv than the KOP valves are permitted by this rule. Note,
however, that all valves and fittings must connect to, and use, 0.160" ID pneumatic tubing.
This is a safety constraint (as the Cv for the entire pneumatic system is dominated by the
tubing flow rate) and must not be violated.
Unread 03-02-2010, 17:15
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Wait, so you're complaining about not being able to use a part that you purchased before you knew the new games' rules (and a rule that existed in 2009 as well)? Did you complain about not being able to use traction wheels last year, as well?
Unread 03-02-2010, 19:25
martin417's Avatar
AKA: Martin Wilson
Perhaps people are misunderstanding the gist of this thread. I am not complaining (well, maybe a little). The title of the thread is "reasoning of the GDC" The purpose of the thread is not to complain, or to bash the GDC.
I started this thread as a discussion about the motivation and reasoning that goes into rules and decisions made by the GDC. I was using the valve rule as a case study on this subject. What could be the motivation behind limiting the Cv to .32? It is NOT flow limitation, because it is legal to use as many valves as you like, connected in parallel to create a Cv as high as you would like, provided you have the money to buy the valves. It is possible that, as AL said, rules are put in place as constraints to make teams think. I doubt that is the case here, because it doesn't take much thinking to put two valves in place of one.
So the question is, why the rule? (I realize now that the rule appeared last year, but that doesn't make any difference). One thing that lawmakers (rule makers) in general overlook is the law of unintended consequences. While there may be a perceived reason to make a change, that change may affect many things far beyond what was intended, sometimes, the negative outweighs the positive.
In this case, the restriction favors well funded teams, either by allowing them to get an advantage by using more valves, or by forcing a team to purchase new valves when they have perfectly serviceable ones in stock.(our case). This is, in my view, a negative. I don't see what he positive could be.
Again, not bashing, just putting forward thoughts for discussion. So, if you have a thought, put it out here. Discuss it civilly. Tell me what the positives of this rule might be, and how they outweigh the negatives.
Unread 03-02-2010, 19:50
Martin,
I follow you up to a point but I have to say that there aren't that many well funded teams this year. I would think the majority are struggling as we are. Sign of the times, but I would rather teams be in and struggling than out. Of course it always possible that we feel stronger about GDC decisions this year because we are all struggling. We will know for sure when we get to regionals and find many old friends are not there.
Unread 04-02-2010, 07:44
martin417's Avatar
AKA: Martin Wilson
Martin,
Al,
I agree that times are tough, and many teams are struggling with budget issues. The budget issue is another facet of the law of unintended consequences. Since this thread is about reasoning and motivation for GDC decisions, and it is a stated goal of FIRST to be as inclusive as possible, and to have as many teams in as many places as possible, I think this an excellent topic for discussion.
How do GDC rulings affect the cost of participating in FIRST? We have already discussed the valve rule and two ways it can impact costs, what other examples can we come up with? One positive example is the motor rule. All motors allowed for use are provided in the KOP (with the exception of the optional 3 CIMs this year) That keeps costs down, since teams don't have to worry about competing with other teams using expensive exotic motors.
I am assuming that members of the GDC read posts here on CD, and want this to be a thought provoking exercise that may bring up points of view they haven't explored. So when responding, please stay on the topic at hand, be polite, positive, and constructive. I don't want this thread to turn into a complaint fest.
Unread 04-02-2010, 08:02
Martin,
Some of the indicators will be the number of robots that show up with the kit frame and wheel standoffs. Another less accurate indicator will be how many students travel to out of town events or how many second events teams are registered for. Some of the restrictions that the GDC has included in the rules tend to limit the functionality of the robots. This may be in part a method of leveling the field and part limiting the need for teams to design and build do all robots. This is the first year in a ball game that robots can't carry or possess more than one ball. That leaves teams with no ball pickup to design and pay for.
Unread 04-02-2010, 10:18
tomgee4me tomgee4me is offline
FRC #3323
tomgee4me is an unknown quantity at this point
Martin,
I just read your post and got worried. We are a rookie team that has done exactly what you cite as an example case. I just read through Update #7 and am not quite sure what you mean when you say the lower part of the frame will be in violation. Are you talking about the bolt heads that would be protruding beyond the actual frame?
Thanks for pointing this out.
Tom Gee
Mentor, Rookie Team #3323
Unread 04-02-2010, 10:23
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Originally Posted by tomgee4me View Post
Martin,
Tom Gee
He is talking about boltheads protruding outside the frame perimeter that are outside of the bumperzone. They are illegal as per Team Update #7.
If you have any questions, PM me (or since you are somewhat local contact me through our teams website) and I'll help you out (if needed).
___________________
- Tennyson, Ulysses
Unread 04-02-2010, 10:25
johnr johnr is offline
FRC #0910
johnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond repute
You may want to read this thread http://www.chiefdelphi.com/forums/sh...threadid=81042
Unread 04-02-2010, 10:30
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The restriction also encourages teams to think of other ways to solve the problem. How about designing a gearbox/mechanism and using a motor to make it work, instead of buying several expensive valves?
I don't worry much about the reasoning of the GDC. I understand that the committee works in strange and mysterious ways, and accept it. The rules are what they are, and we'll work within them as best we can.
Unread 04-02-2010, 11:27
AdamHeard's Avatar
Lead Mentor
Whenever I get really frustrated with the GDC and their most annoying rules that I think are really arbitrary, I stop and think that this is nothing compared to the ridiculous amount of rules one must work towards in most large engineering firms. I guess they're just preparing my students and I for the real world?
Unread 04-02-2010, 11:34
I guess it's possible that the GDC made the rule to save teams money, but I think it's far more likely that we are seeing "robot soccer" in which "hands" aren't legal.
Unread 10-02-2010, 08:30
martin417's Avatar
AKA: Martin Wilson
A new question on the reasoning of the GDC:
Why be deliberately vague in rules and Q&A?
There has much discussion here on CD about the meaning and intent of several rules, earlier it was fasteners protruding beyond the frame perimeter, lately is has been about electromagnets. These questions have been asked multiple times, and several different ways, with no crystal clear answer from the GDC. When several inspectors have posted that they don't know what the rule means, it looks like trouble, if the inspectors can't figure it out and agree, how is a team supposed to?
Why be deliberately vague? How does vagueness impact the aforementioned criteria?
1) safety
2) Game-play
3) Damage prevention
4) Fairness
(I realize that these criteria are mine not the GDC's)
I see several negative impacts of vagueness:
1) A team's design ruled illegal at competition
2) Discourages a team from attempting a novel approach because they can't figure out if it is legal or not.
3) May force a team to abandon an idea they assume is illegal, but isn't
4) causes delays in an already tight schedule while trying to understand the rules, get answers from Q&A etc.
Perhaps these are intended consequences, and are exactly what the GDC wants to happen. It is a lot like real life, unclear customer requirements, poorly written statement of work, bad communication from the sales / marketing team etc.
But again, are we modeling real life, or playing a game? If the teams and inspectors can't figure out the rules, how will spectators? Since the game is brand new every year, there hasn't been years of refinement and interpretation to perfect the rules like in most sporting events, so clarity and completeness is much more critical.
[opinion]I think the GDC needs to abandon its policy of inscrutability and adopt a policy of openness and clarity.[/opinion]
Here's the GDC we know and love GaryVoshol General Forum 29 22-01-2010 20:03
Dear GDC Tetraman FRC Game Design 6 30-03-2009 21:52
Here's the GDC we know and love GaryVoshol General Forum 30 06-02-2009 07:37
Dear GDC, johnr FRC Game Design 10 09-01-2009 11:11
A little GP for the refs and GDC... efoote868 General Forum 2 14-04-2008 23:02
