Go to Post One of the many unwritten laws of engineering failure is that the problem will occur in the most inopportune time. - Dave Scheck [more]
Unread 04-02-2010, 09:14
ThisAintJeff's Avatar
ThisAintJeff ThisAintJeff is offline
FRC #1591 (Greece Gladiators)
ThisAintJeff is an unknown quantity at this point
Send a message via AIM to ThisAintJeff
Modify Wheels?
Are we able to modify the wheels at all? our idea involves xcrewing something into the rubber part of the wheel, and we're just checking to make sure its still allowed
Unread 04-02-2010, 09:29
cbeavers6790's Avatar
cbeavers6790 cbeavers6790 is offline
AKA: carroll
FRC #3542 (Team S.P.E.E.D)
cbeavers6790 will become famous soon enough
Re: Modify Wheels?
i am not positive because i am in school and dont have my rule binder, but if you are going to put stuff in the wheels you have to check the safety rules. If what you are putting in can damage the field or other robots it would be out, but i would read the rules very carefully to see if this is allowed.
IM THE ENFORCER OF ALL RULES (at least the ones in the manual)
Unread 04-02-2010, 09:35
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
Re: Modify Wheels?
You are allowed to use any wheel you want to, or to modify any wheel to fit your needs. As long as you do not damage the floor or have metal in contact with the floor.
<R08> ROBOT wheels, tracks, and other parts intended to provide traction on the FIELD may be purchased or fabricated (“traction devices” include all parts of the ROBOT that are designed to transmit any propulsive and/or braking forces between the ROBOT and the FIELD). In no case will traction devices that damage the carpet or other playing surfaces be permitted. Traction devices shall not have surface features such as metal, sandpaper, hard plastic studs, cleats, or other attachments. Anchors (i.e. devices that are deployed/used to keep one’s ROBOT in one place and prevent if from being moved by another ROBOT) shall not use metal in contact with the carpet to “stay put.” Gaining traction by using adhesives or Velcro-like fastener material is not allowed.
Re: Modify Wheels?
http://usfirst.org/uploadedFiles/Com...Robot_RevG.pdf
Click on the above link and go to Rule <R08>
If that doesn't answer your question, ask your designated team Q&A person to post a question to this forum:
http://forums.usfirst.org/forumdisplay.php?f=1391
Unread 04-02-2010, 10:54
pilum40 pilum40 is offline
Steve Miller-Coach-Team 3355
AKA: Steve Miller
FRC #3355 (Bigg Redd)
pilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud of
Re: Modify Wheels?
sorry to hijack this thread (just a little) We're a rookie team and wanted to know if we were restricted to using the 8" standard wheels or could we use 4"/6" wheels with traction tread from Andymark? We are thinking that lowering the height by 4" would allow us to get through the tunnel easier plus would lower our C.G; but, may pose a problem getting "over the hump". Has anyone else tried this or considered it?
Thanks!
Steve Miller
Summit International Prep
Team 3355
Arlington, Texas
Unread 04-02-2010, 10:57
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Modify Wheels?
You can definitely use those 4 or 6 inch wheels.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 04-02-2010, 11:08
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Modify Wheels?
We are using 6" wheels
Unread 04-02-2010, 11:53
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Modify Wheels?
Thanks!
Steve Miller
Team 3355
Arlington, Texas
Just remember that your bumpers must still be in the bumper zone (10-16" from the floor) in the NORMAL CONFIGURATION
___________________
- Tennyson, Ulysses
Can we modify wheel brackets ? please relpy gkiller19 Technical Discussion 2 19-01-2010 12:42
6 wheels with only 2 powered wheels bhsrobotics1671 General Forum 15 14-01-2008 17:28
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Image Discuss: Wheels- you want wheels - more from team 25 CD47-Bot Extra Discussion 10 07-09-2003 20:33
Wonder Wheels (aka Side Slip Wheels) Scott358 Technical Discussion 4 08-01-2002 12:36
