Go to Post I respect each member of any FIRST team that is truly trying to help students…how they choose to do so is up to them. - Jason Kixmiller [more]
Unread 04-02-2010, 11:50
mac7attack mac7attack is offline
AKA: Mac7Attack
FRC #2108 (Team Awkward Turtle)
mac7attack is an unknown quantity at this point
Bumper Backing
In rule <R07> specifies the bumper must be supported by the frame.
M. The entire length of the BUMPER backing must be supported by the structure/frame of the ROBOT (i.e. the backing material must not be in “free space” between or beyond attachment points) (see Figure 8 – 3).
We have a preliminary design that puts 4 steel vertical bars on the bumper backing to hold it in between the 8020 frame. Bumper is about 5 inches tall, 8020 frame is about 9 inches between the top and bottom bar.
Would this design satisfy <R07M> or does the back of the bumper have to be directly mounted to the robot frame/8020?
Thanks,
Matt
FRC Team 2108 - Team Awkward Turtle
Unread 04-02-2010, 11:56
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Bumper Backing
Thanks,
Matt
To satisfy <R07-M> the back of the bumper must be supported along it's entire length. The easiest (and only) way I have seen this done is with a horizontal member.
To use vertical members there would likely have to be a whole lot of them to support the entire length of the bumper.
Unread 04-02-2010, 11:57
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Bumper Backing
Sounds like you have a few spans of "free space" behind the bumper, doesn't it?
See if there's a way to run one horizontal frame member (or steel support piece) all along behind the bumper, about midway up it.
We designed our frame to have it's upper structural piece made as a big rectangle of squre tubing, at the middle of the bumper zone. We'll have brackets at the corners that go up above the frame, to allow the bumper bolts to attach.
http://www.chiefdelphi.com/forums/sh...5&postcount=28
Bumper Plywood Backing Skifanatic Technical Discussion 3 10-02-2009 18:20
Bumper Qs Woody1458 General Forum 13 29-01-2009 16:41
Hardware Issues / Backing up data MattD Chit-Chat 18 23-07-2006 22:16
Europeans Seek More Backing for Robotics Elgin Clock Math and Science 1 22-01-2006 21:26
Bumper or No? WebWader125 Technical Discussion 19 11-01-2006 01:28
