Go to Post That's right 10 years and this is the first time ever that the school wanted anything to do with the FIRST team. - RoteAugen [more]
Unread 04-02-2010, 13:28
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
Bumper Wall Attachment
Hi all,
Just wanted to get a second opinion to make sure we don't show up at inspection and have this wrong. The attached image shows some angle aluminum that would be used to mount the bumper wall to the frame. It also show fastener heads off the back of the recommended aluminum angle used to hold on the cloth. Are these both legal per R-7N?
Also - I was curious if it was better to use angle as shown in green or use the Tee nuts that they show in the manual. This is my first year doing FIRST and I wanted to make sure this is a very robust connection.
Thanks!
Unread 04-02-2010, 13:33
Re: Bumper Wall Attachment
Looks OK. The fastener heads will probably count towards bumper weight, but you almost have to try to get a 15# bumper, let alone a 20# one.
The tight and robust connection called for is up to you. If, for example, you fastened through the angle to the top of a frame member, that would most likely be a good connection, unless you did something wrong.
Unread 04-02-2010, 13:41
The Megan 2207's Avatar
The Megan 2207 The Megan 2207 is offline
FRC #2207 (Prime 329)
The Megan 2207 is just really niceThe Megan 2207 is just really niceThe Megan 2207 is just really niceThe Megan 2207 is just really nice
I'm not sure why you're specifically referencing <R07-N>, as this part of the rule only deals with how far the "hard" or "soft" parts of the bumper can extend from the frame perimeter.
My team has used a very similar angle attachment method for the past few years, but instead of attaching the angle to the bumper, we attach it to the robot and attach the bumpers by bolting through the angle. We find this is easier than trying to blindly attach the bumpers through the c-channel kitbot frame (we usually use that for our chassis).
From my understanding of the bumper rules, a protruding bolt head is perfectly legal, as it would only extend under your robot's frame. We normally just use wood screws to hold the angle in place, and we've never had a problem with that.
Unread 04-02-2010, 13:48
JB987 JB987 is online now
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Your question is a good one that many would benefit from knowing an official answer to. Why not direct it (with included image) to the Q and A forum to establish a "legal" interpretation we may cite should an inspector have a different interpretation?
Unread 04-02-2010, 13:51
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Originally Posted by aldaeron View Post
Hi all,
Thanks!
we used angle brackets last year and they work great
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 04-02-2010, 14:03
AKA: -matto-
FRC #1410 (Kraken)
I forgot to draw the FRAME PERIMETER. Is it the red line or the black line in the new picture?
Name:	Bumper Wall2.jpg
Unread 04-02-2010, 14:21
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Red Line
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 04-02-2010, 14:26
AKA: -matto-
FRC #1410 (Kraken)
Much obliged. That is what I thought, but I didn't want to get it wrong. There are a lot of nuances to all the rules and I don't want to be wrong.
Unread 04-02-2010, 16:35
GaryVoshol's Avatar
Cogito ergo arbitro
You would want to be sure that any protrusions on the back of the bumper board don't interfere with a tight robust fit of your bumper to the frame.
Wood to frame = good
Bolthead to frame = bad, because of small contact area
(since 2004)
Unread 04-02-2010, 16:51
AKA: -matto-
FRC #1410 (Kraken)
I am trying to get an opinion on which of these options has worked better in the past. The light blue square is the box beam from the chassis.
Name:	Bumper Wall3.jpg
Unread 04-02-2010, 17:07
martinswat1806 martinswat1806 is offline
AKA: Zach Martin
FRC #1806 (SWAT Robotics)
martinswat1806 has a spectacular aura aboutmartinswat1806 has a spectacular aura aboutmartinswat1806 has a spectacular aura about
What we have learned, and it all depends on the design of your robot, is to put a rectangle tube of aluminum on the back side of the bumper that fits into a slot on the frame of your robot then you just drill a hole from top to bottom and pin it in place using a long bolt. Hope it helps.
Unread 04-02-2010, 18:24
aldaeron,
I just want you to be sure as I was a little confused when I first looked at your post. The angle aluminum shown in the bumper drawing is to secure the cloth covering to the plywood backing. It is not the attachment but is merely clamping the cloth in place. In the drawing, the bolt threaded into the blind nut is the attachment.
The drawings you submitted are both used by teams but the one using the additional angle is sometimes more easy to remove. However, the support angle is generally weighed as part of the robot.
From <R07>
G. Each set of BUMPERS (including any fasteners and/or structures that attach them to the ROBOT) must weigh no more than 20 pounds.
H. BUMPERS must be designed for quick and easy installation and removal, to aid in weighing and inspection (as a guideline, BUMPERS should be removable by one person in less than ten minutes).
I. BUMPERS must attach to the FRAME PERIMETER of the ROBOT with a rigid fastening system to form a tight, robust connection to the main structure/frame (e.g. not attached with Velcro). The attachment system must be designed to withstand vigorous game play – nut and bolt fasteners are recommended. All removable fasteners (e.g. bolts, locking pins, pip-pins, etc.) will be considered part of the BUMPERS.
J. If a multi-part attachment system is utilized (e.g. interlocking brackets on the ROBOT and the BUMPER), then the elements permanently attached to the ROBOT will be considered part of the ROBOT, and the elements attached to the BUMPERS will be considered part of the BUMPER. Each element must satisfy all applicable rules for the relevant system.
Unread 04-02-2010, 18:27
AKA: -matto-
FRC #1410 (Kraken)
aldaeron,
I just want you to be sure. The angle aluminum shown in the bumper drawing is to secure the cloth covering to the plywood backing. It is not the attachment but is merely clamping the cloth in place. In the drawing, the bolt threaded into the blind nut is the attachment.
The Grey Angle Aluminum is used to clamp down the fabric
Unread 04-02-2010, 19:07
AKA: -matto-
FRC #1410 (Kraken)
Al,
In the left design, would the green piece of angle count as part of the robot? I was planning to attach it with wood screws (the horizontal black screw looking thing) meaning it would not be meant to be removed. Then I would use bolts (the vertical black screw looking thing) to attach to tapped holes in the frame.
To me that seems like it falls under part G and I and therefore the weight counts as the bumper weight not the robot weight.
Thanks!
Unread 04-02-2010, 19:25
GaryVoshol's Avatar
Cogito ergo arbitro
Of the two examples, the second is a more robust connection. The frame member is in the middle of the backer board. The one with the frame at the bottom of the board will have much greater forces on the connectors when it gets hit at the top of the bumper.
AndyMark sells some bumper kits, and you can see how pairs of the brackets used here: http://store.andymark.biz/am-0325.html
To see how the brackets work, look at the pdf link "Bumper Segment Example Layout" on that page.
They also sell c-channel brackets: http://store.andymark.biz/am-0317.html
Al's the inspector, not I, but in my opinion if the brackets remain attached to the bumper, they are weighed with the bumper, as is the connector bolt or pin.
By the way, for anyone still reading, this is an example of a good way to ask questions. aldaeron did some research, drew diagrams, referenced the rules, and asked for confirmation. Much better than a terse "How do you think I should attach my bumpers?" query. Rep given.
(since 2004)
Bumper Attachment for Rapid Removal Dale Technical Discussion 26 04-01-2010 17:10
2060 attachment chain availability Bruceb General Forum 6 20-12-2008 10:12
AM Super Shifter -- pneumatic attachment JesseK Technical Discussion 4 24-11-2008 12:29
Bumper Attachment bLuEpHoEnIx Technical Discussion 12 18-02-2006 20:22
Attachment Types russell CD Forum Support 6 24-02-2005 10:12
