Go to Post ...UFH nominations are like jello, there is always room for one more. - Barry Bonzack [more]
Unread 04-02-2010, 14:00
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: AndyMark Nano Break In
Originally Posted by Rob View Post
Playing with the CAD model a bit I can see where the spacer would be needed on the output shaft. That end of the output shaft (between the last gear and the inside of the plate) is a 1/2" hex on both versions of the output shaft.
I would imagine that a washer with a round hole would function and that you don't need to match the hex shape to get this right. I will be stopping at the hardware store tonight and hoping that our NANO order is in today
As far as the sticky CIM pinions I can say that we observed that on one pinion from the KOP this year. It was not very bad and wore in quickly running the transmission on a bench. I can see how a small variation here would quickly cause a problem.
Rob
There is a large washer on that shaft that is not in the cad file. It goes between the large bearing and large output gear.
TB Nano Encoder Spacing daltore Kit & Additional Hardware 5 24-01-2010 11:17
pic: AndyMark has the Nano; we have the Shuffle! rob_c Extra Discussion 10 19-01-2010 22:30
pic: I love the nano Akash Rastogi Extra Discussion 6 02-11-2009 18:19
Lost iPod Nano - SVR Otaku General Forum 0 02-04-2007 21:20
