Go to Post Are you saying you want to submerge your circuit board in an open container of liquid nitrogen? - Ether [more]
Unread 04-02-2010, 14:05
Alexis Howell's Avatar
Alexis Howell Alexis Howell is offline
FRC #2557 (Sota Bots)
Alexis Howell is an unknown quantity at this point
Re: #1860 kicker prototype
So did you just program a limiter onto the motor? Does it reverse, or is the motor somehow mechanically pulled away from the kicker?
This looks really effective! good job.
"That's not a robot! That's a keg and a boombox... on a skateboard."
Unread 04-02-2010, 14:27
sloteera's Avatar
sloteera sloteera is offline
AKA: Rafa
FRC #1860 (Cephatron)
sloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud of
We are using two limit's sensors (in order to provide for us two positions: the armed position for the kick and the position after of the kick. Note: the same sensor which detect that the ball was been kicked will detect if there is some ball for kick).
So we keep our kick armed within FRAME PERIMETER and when the driver to press the button, the CIM motor turns forward. After kick, CIM motor turns reverse and keep armed position.
By PWM variation we can change how far the ball goes!
Note: we'll adapt some mechanism to guarantee that pendulum will keep the armed position when the robot move yourself.
Rookie Team 3357 The COMETS Kicker Prototype GGCO Robot Showcase 21 19-01-2010 23:06
#1860 proudly thanks some teams: sloteera Thanks and/or Congrats 1 23-03-2009 01:00
Team 241's Turret Prototype ontop of the Harvester Prototype Dantvman27 Robot Showcase 39 08-02-2009 22:53
Video: #1860 camera tracking sloteera Programming 2 01-02-2009 23:29
pic: team 1860 willianst8 Extra Discussion 1 06-04-2008 22:37
