Go to Post If you are "retiring" the old ball, make all the lights green, hang it 8 feet in the air, line up a bunch of 'bots and let 'em shoot poofs. RoboPinata! (warning kids - don't eat the "candy" that falls out!) - Taylor [more]
Unread 17-01-2010, 15:54
sloteera's Avatar
sloteera sloteera is offline
AKA: Rafa
FRC #1860 (Cephatron)
sloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud of
#1860 kicker prototype
http://www.youtube.com/watch?v=QMqMi_OIuRY
Our kicker prototype
At the moment, we are only using the correct angle for kick, but aren't considering the air drag!
We would appreciate any feedback!
Unread 17-01-2010, 16:31
J_Beth J_Beth is offline
AKA: Justin Beth
FRC #0935 (RaileRobotics)
J_Beth will become famous soon enoughJ_Beth will become famous soon enough
Re: #1860 kicker prototype
Looks good! How far from the bump is your kicker? Is it pneumatic or does it use surgical tubing?
"I Wanna Be A Robot Maker!!!!"
Unread 17-01-2010, 16:47
sloteera's Avatar
AKA: Rafa
It's near of the floor. The bumper is placed with 10 inches above the floor, so the point of contact between kicker and ball is nearly 9,5inches. We are using a motor with gear box!!
Unread 17-01-2010, 16:51
Josh Drake's Avatar
Josh Drake Josh Drake is offline
Engineering Mentor
FRC #5403 (Aluminosity)
Josh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond repute
Looks good. A lot of teams have shown kickers that are being cocked by hand, but it's nice to see one that's motorized.
07'-10' FRC 343
11'-12' FRC 2751
13'-14' FRC 3494
15'-16' FRC 5403
Unread 17-01-2010, 17:36
We're playing soccer this year, 1860 better win the World Champs in Atlanta this year.
Unread 17-01-2010, 17:39
b787bydesign b787bydesign is offline
Mesh
AKA: Dr. Santiago
FRC #2791 (Terminal Velocity)
b787bydesign is on a distinguished road
Send a message via AIM to b787bydesign
Hmm - very nice - is the kicker fairly accurate with every "kick" (in terms of direction, speed, ball control?) Also, is the reset time fairly fast?
Animesh Hajela
Shaker Robotics (Terminal Velocity)
"All putts intercept CAT IIIc ILS glideslopes."
Unread 17-01-2010, 19:48
sloteera's Avatar
AKA: Rafa
I think that the main trouble that we're having is the ball position for the kick at the moment.
Before this, our main trouble was find the exact angle to kick, because we need consider three fundamental points in the trajectory: the height of the bumper, the height of first bump and the height of the second bump.
We think that we need improve the kicker in order to pass the second bump without touch the floor!!
Unread 17-01-2010, 19:49
sloteera's Avatar
AKA: Rafa
Would be much better if we could put a small guy inside the robot to play the match
Unread 17-01-2010, 22:01
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Just to clarify...your kicker uses ONLY a motor and gearbox to provide the impulse? No tubing or springs???
Unread 17-01-2010, 22:16
sloteera's Avatar
AKA: Rafa
We don't use springs or anything with elastic energy conservation. I don't understood exactly what is "tubbing", but we calculate the force for the kicker based in the centripetal acceleration!!
Unread 17-01-2010, 23:19
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
By "tubing" he was referring to the surgical tubing provided in the kit (stretched out to provide elastic energy). Your answer shows that you're not using it.
Unread 04-02-2010, 14:05
Alexis Howell's Avatar
Alexis Howell Alexis Howell is offline
FRC #2557 (Sota Bots)
Alexis Howell is an unknown quantity at this point
So did you just program a limiter onto the motor? Does it reverse, or is the motor somehow mechanically pulled away from the kicker?
This looks really effective! good job.
"That's not a robot! That's a keg and a boombox... on a skateboard."
Unread 04-02-2010, 14:27
sloteera's Avatar
AKA: Rafa
We are using two limit's sensors (in order to provide for us two positions: the armed position for the kick and the position after of the kick. Note: the same sensor which detect that the ball was been kicked will detect if there is some ball for kick).
So we keep our kick armed within FRAME PERIMETER and when the driver to press the button, the CIM motor turns forward. After kick, CIM motor turns reverse and keep armed position.
By PWM variation we can change how far the ball goes!
Note: we'll adapt some mechanism to guarantee that pendulum will keep the armed position when the robot move yourself.
Rookie Team 3357 The COMETS Kicker Prototype GGCO Robot Showcase 21 19-01-2010 23:06
#1860 proudly thanks some teams: sloteera Thanks and/or Congrats 1 23-03-2009 01:00
Team 241's Turret Prototype ontop of the Harvester Prototype Dantvman27 Robot Showcase 39 08-02-2009 22:53
Video: #1860 camera tracking sloteera Programming 2 01-02-2009 23:29
pic: team 1860 willianst8 Extra Discussion 1 06-04-2008 22:37
