Go to Post We are not the families of competiting robot teams, but we are a family of Gracious and Professionalism, because we know it better than anyone in the world. - wsansewjs [more]
Unread 04-02-2010, 14:54
Galum's Avatar
Galum Galum is offline
AKA: Gal Barkai
FRC #1657 (HaMosad)
Galum is on a distinguished road
Send a message via MSN to Galum
Toughbox stall torque
Just a quick question, does anyone know the stall torque of two CIM motors in an un-modified toughbox?
Thanks in advance
2005, 2006, 2007, 2009, 2010 Israeli Champions
2011 Israeli Finalists 2006, 2007 Israeli RCA
CSA 2012-present
Unread 04-02-2010, 15:05
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Toughbox stall torque
About 56 Newton-Meters
Unread 04-02-2010, 15:28
MCahoon MCahoon is offline
FRC #3826 (Sequim Robotics Federation)
MCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud of
For about 5 seconds
Unread 04-02-2010, 15:34
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Be careful. You should be engineering for 1/2 stall torque or less to get the maximum power out of your motors. In addition, the CIM's stall at 129 amps and you are only allowed 40 amp breakers.
Unread 04-02-2010, 15:47
Galum's Avatar
AKA: Gal Barkai
FRC #1657 (HaMosad)
We know that, we just used that as an indicator in order to compare the torque between a regular toughbox with two CIMs and a 1:25 transmission with only one CIM; thanks for the quick replays =)
CSA 2012-present
[FTC]: Caution - Tetrix Motors burn out on Stall ptan FIRST Tech Challenge 3 11-02-2009 10:19
motor stall current vs Victor ratings dawilliams Electrical 30 03-01-2007 08:29
Made to stall srjjs Motors 5 17-01-2003 19:00
What happens / why do motors stall? DanL Technical Discussion 19 21-11-2002 07:19
So you want to stall a Globe Motor... archiver 2000 1 24-06-2002 00:09
