Go to Post All the robots win, because we built them and they work. ;) - synth3tk [more]
Unread 31-01-2009, 17:29
ExarKun666's Avatar
ExarKun666 ExarKun666 is offline
Ben Error/MC Ben/NC Ben
AKA: Ben Kellogg
FRC #2429 (LCEC)
ExarKun666 is an unknown quantity at this point
Send a message via AIM to ExarKun666 Send a message via MSN to ExarKun666 Send a message via Yahoo to ExarKun666
Connecting to Download code in WindRiver
Okay we looked at the programmers guide on the FIRST site, and followed the instructions to download code to the robot (wired, not wireless) and we are getting an error every time we try to connect to the cRIO, we chaged our team number in Window->Properties, and have connected the ethernet ports in several different configurations, and the error we get is:
Error connecting to 'VxWorks6x_10.24.29.2'(Registry localhost). Failed to
launch target server
Possibly caused by: Back-end not connected.
Removed dead entry from Registry!
What is the configuration of the ethernet ports? What is the problem here? TY to any who reply.
Ben Kellogg
Team Sites: [LCEC Site] [FRC/FLL Site] [LCEC Blog]
Unread 31-01-2009, 18:14
Maxpower57's Avatar
Maxpower57 Maxpower57 is offline
Fabuloso
AKA: Maxwell V.
FRC #2574 (RoboHuskie)
Maxpower57 will become famous soon enoughMaxpower57 will become famous soon enough
Send a message via AIM to Maxpower57
Re: Connecting to Download code in WindRiver
If you're connecting directly without the wireless, are you using a crossover cable and not an Ethernet cable?
Unread 31-01-2009, 18:26
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
we are using ethernet... we will try crossover and see
Ben Kellogg
Unread 31-01-2009, 23:02
Can you try this specific sequence of steps:
1) Start Wind River
2) Try to connect (and get the error message)
3) Leave Wind River running
4) Start the FRC cRIO Imaging Tool
5) Choose the Development Environment Wind River and Apply (don't reformat the controller)
6) Return to Wind River and try to connect again
Unread 01-02-2009, 02:50
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
somehow some way, which I think we accidently stumbled into, we solved all the problems, because we have been trying to download code, and been trying to get the wireless working simultaneously since the competition began, and today we got both to work, we aren't completely sure of how we accidentally found the solution, but we are glad that we did!
Ben Kellogg
Unread 02-02-2009, 13:50
intellec7's Avatar
intellec7 intellec7 is offline
108 programmer
AKA: Gustavo
FRC #0108 (SigmaC@ts)
intellec7 is on a distinguished road
Send a message via AIM to intellec7 Send a message via MSN to intellec7
I remember receiving a similar or same error message and it was because we had the LabVIEW image loaded instead of the WindRiver one.
Unread 04-02-2010, 15:31
mutantblond mutantblond is offline
FRC #2523
mutantblond is an unknown quantity at this point
We suspect that we have the wrong version of Windriver (we think we have 3.0, but think we need 4.0) - we've downloaded the workbench updater, but it doesn't seem to update anything when we run it. It says that it's extracting to a folder that doesn't exist, and runs a command prompt for a few seconds, then closes. Our error, when we try to connect Windriver to the CRio, we get the error message "possibly caused by back-end not connected".
what IP address should our computer have? Our computer can ping the robot.
Unread 04-02-2010, 15:42
Caleigh C Caleigh C is offline
None #2523
Caleigh C is an unknown quantity at this point
What is a crossover cable? We're using Ethernet right now. Thanks
Unread 04-02-2010, 16:13
An Ethernet jack for twisted pair wiring (pretty much the only kind of Ethernet jack you'll ever see) has specific pins defined for data out and for data in. In order to connect two normal jacks together, you have to use a cable that swaps the wires so that data out of one jack goes to data in of the other. That's a crossover cable.
Ethernet hubs and switches have "crossover" jacks, so to connect to them you use a straight-through or "patch" cable. That's the normal kind of Ethernet cable, since it's rare to connect only two devices together without a hub.
For years, most modern computers' Ethernet adapters have had the ability to automatically sense what they're connected to and swap their connections appropriately, so crossover cables are not often required. One place they are required is between the cRIO and the Axis 206 camera, because neither of those two devices will do internal crossover automatically.
Building WindRiver Code? lingomaniac88 Programming 4 28-01-2009 17:09
Windriver downloading code problems. HUmar104 C/C++ 4 25-01-2009 20:53
[Windriver] Getting error on run: Download Failed JHale C/C++ 4 15-01-2009 07:42
Problem debugging code with WindRiver LinuxMercedes Programming 3 07-01-2009 11:10
Can't Download Code nickmagus Programming 1 05-01-2009 17:52
