Go to Post The GDC made something easier??? Link or it didn't happen! - JesseK [more]
Unread 04-02-2010, 16:02
Team1824 Team1824 is offline
FRC #1824
Team1824 is an unknown quantity at this point
Re: error in Autonomous independent when using "run as startup"
Yes the autonomous independent is being called in the begin.vi. What the code is supposed to do is use the default auto independent code to center the target and then move forward. However the camera is not hooked up so is that the problem? I was assuming that it would simply skip the camera code and go right to the movement code but I guess that might not be the case...?
Team 1824
[FTC]: Autonomous Deployment Error "1003" neblixsaber FIRST Tech Challenge 2 28-12-2009 12:55
Using Sensors in Autonomous Independent Felipe Sagui NI LabVIEW 2 27-01-2009 17:25
cRio losing connection when "run as startup" mgurgol Programming 2 12-01-2009 12:18
Will 3ds Max 2009 run on "regular" Windows XP? Kevin Thorp 3D Animation and Competition 3 12-11-2008 22:07
how tall is the ramp when in "up" and "balanced" position??? archiver 2001 1 24-06-2002 00:54
