Go to Post it takes a village to raise a robot. - Taylor [more]
Unread 02-02-2010, 11:48
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Sometimes Bumpers & Kickers don't mix
Yesterday when we put bumpers in the correct position on our kicker prototype and kicked , we found out the ball hit the bumper and deflected noticeably. When we did the math we found out why. Our ball is 3 inches deep in the robot when kicked. That makes the top of the ball another 1 1/2 inches outside the perimeter. The bumper is a 2 1/2 pool noodle on a 3/4 piece of plywood. The bottom of the bumper could be as low as 10 inches above the ground or only one inch above the top of the ball. Doing the math a triangle with a base of 1 3/4 (3 1/4 - 1 1/2) with the other side of 1 inch has an angle of 30 deg. That means a ball leaving the robot at an angle of more than 30 deg is going to hit. If the top of the bumper is 16 inches above the ground then the triangle other side is 2 inches. That makes the angle a little over 45 deg. That means if you kicker is designed for max range (ie 45 deg) it's probably going to hit also. Bottom line is you really ought to try out your kicker with bumpers in place before you finalize your design. We're redesigning our kicking shoe for a flatter kick. I'm glad we found this out now rather that we tried to kick the first time we had the robot completely together
Unread 02-02-2010, 12:00
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Sometimes Bumpers & Kickers don't mix
I get the feeling that the evil GDC really has their act together this year.
Unread 02-02-2010, 12:28
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
GDC- smarter than we ever thought they were!
1058 PVC Pirates 2016 - xxxx
Unread 02-02-2010, 12:40
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
No doubt. I've had more than one vision of GDC lunchtime sketches and right triangle math followed be maniacal laughter from the insidious ones.
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Unread 02-02-2010, 13:33
I must be misunderstanding what you've written. It sounds like the radius of the ball you are using is 4.5" This is not regulation.
Could you please clarify?
Thanks!
Unread 02-02-2010, 13:50
MrForbes's Avatar
AKA: Jim
6.3.1 BALLS
While playing Breakaway, ROBOTS manipulate BALLS to accomplish the objectives of the game. Each BALL is a standard Size 5 soccer ball. The BALL weighs between 14 and 16 ounces, has a circumference of 27 to 28 inches, and is inflated to a standard pressure of approximately 9psi.
let's see....28" / 2 pi = 4.45" so the spec ball radius could be pretty close to 4.5"
at least to within the accuracy that you can measure the position of the lower front corner of the bumper!
Unread 02-02-2010, 13:53
You are correct. My bad. I was going from memory. Not a wise thing to do at my age.
Unread 02-02-2010, 14:33
GaryVoshol's Avatar
Cogito ergo arbitro
You'll regain a wee bit on the curve of the pool noodle profile. I remember quantifying this back in Aim High to calculate our approach angle for the ramp.
(since 2004)
Unread 02-02-2010, 17:10
andy174drive's Avatar
andy174drive andy174drive is offline
FRC Team 0174
AKA: Andy Dodd
FRC #0174 (Arctic Warriors)
Team Role: Driver
andy174drive is an unknown quantity at this point
Send a message via AIM to andy174drive
This problem has been on my mind as well but I have yet to test it. Does your kicker stay inside your chassis or does it go out the full allowable distance?
Unread 02-02-2010, 17:24
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
What do you mean specifically by a flatter kick?
Changing the kicker point of contact design with the ball mechanism or the angle in which the current kicker makes contact with the ball.
Unread 02-02-2010, 20:13
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
Hi Glenn...I mean by flatter that the ball will leave the kicking mechanism at a lower trajectory angle. We've been playing with different angled kicking plates all afternoon and still haven't got it right. The next thing we may do is play with where the kicker plate makes contact with the ball. Currently we're contacting the ball about 2 inches off the floor. The other thing that's making the situation worse is back spin from the dribbler. We've finally got the ball to miss the bumpers with the dribbler off. With it on the ball climbs the kicking plate and increases loft which means its still hitting the bumpers.
Unread 03-02-2010, 20:16
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
they measure the 3" from the frame perimiter
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 04-02-2010, 14:15
Alexis Howell's Avatar
Alexis Howell Alexis Howell is offline
FRC #2557 (Sota Bots)
Alexis Howell is an unknown quantity at this point
You could perhaps modify the bumper brackets to give you more clearance. That's if you still want to maintain maximum trajectory. How high up are your bumpers?
"That's not a robot! That's a keg and a boombox... on a skateboard."
Unread 04-02-2010, 15:45
run the trap!!!
Team Role: Human Player
The bumpers are 5" tall, and the bumper range is 10-16" above the floor. So couldn't you move them up a little and get 2.25" of clearance above the ball?
The bumpers are also rounded, so the ball can go "through" them a little.
And unless you're getting really far under the ball with your kicker, its pretty hard to get 45* anyhow...
-Philip J. Fry
Unread 04-02-2010, 16:13
Electrical Engineer
Rookie Year: 1995
Originally Posted by =Martin=Taylor= View Post
...And unless you're getting really far under the ball with your kicker, its pretty hard to get 45* anyhow...
Martin,
Not really...
Many teams are eventually going to find hitting the bottom of their bumper an issue...
JMHO,
Mike
Mike Betts
As easy as 355/113...
Regulatig Pressure on Pneumatic Kickers jamie_1930 Pneumatics 1 26-01-2010 20:24
spinning kickers Da Kid Rules/Strategy 7 24-01-2010 00:38
Metal Shavings and RC don't mix Chris_Elston Electrical 17 19-03-2008 20:24
Bumpers & the Ramp Gary Bonner Rules/Strategy 2 26-01-2006 11:13
Q&A Discuss: Bumpers CD47-Bot Extra Discussion 1 05-02-2003 17:12
