Go to Post Meanwhile, it's water over the dam, spilled milk, etc. Let's drop the subject and get on with life. I am seeing people warming up their lawyerism, which is not a good thing when we are coming up on build season. - EricH [more]
Unread 04-02-2010, 16:17
Sam2197's Avatar
Sam2197 Sam2197 is offline
FRC #2197 (Las Pumas)
Team Role: Driver
Sam2197 will become famous soon enough
taigene motor
are we allowed to use the taigene motor from delphi. not sure what rule it would fall under i cant remember when we get this one.
Unread 04-02-2010, 16:19
GaryVoshol's Avatar
Cogito ergo arbitro
Re: taigene motor
If it didn't come in this year's kit, you can't use it. <R52> and <R53>.
(since 2004)
Unread 06-02-2010, 20:34
grdaneault grdaneault is offline
FRC #2497
grdaneault is an unknown quantity at this point
Re: taigene motor
What about clause B in R52: (An unlimited number of COTS servos with a maximum output torque of 55 oz-in and maximum rotational speed of 100 rpm at 6 Vdc (e.g. HITEC model HS-322HD or HS-325HB servos, as provided in the KOP)
So long as the taigene conforms to these standards shouldn't it be allowed? Can anyone confirm the specs for it?
Unread 06-02-2010, 20:52
Re: taigene motor
It's a motor, not a servo. Therefore, <R52-B> does not apply.
And I'd say it's a pretty safe bet (not remembering the specs offhand) that it can beat that output torque really easily, if not the RPM, even if it were counted as a servo.
If you look at the specs for this year's window motors, the Taigene would be somewhat similar, IIRC.
Taigene Van door motor scimino Motors 3 15-03-2008 15:34
Taigene Window Motor Information CoupeSprinter Motors 4 29-01-2008 20:27
taigene motor shaft wildabyss Technical Discussion 3 24-01-2008 17:11
Taigene Motor Specs Guy_E Motors 7 21-01-2008 03:25
White Paper Discuss: Approx. Motor Spec for Taigene Motor Joe Johnson Motors 2 22-01-2005 16:36
