#16
Re: Fisher Price Motor Power
Just so we are all on the same page, the thermal protection device is a bi-metal actuated switch. If you solder connections to the FP be careful as it may cause some misalignment of the contacts.
#17
Thanks for the warning. We did use the big soldering iron when soldering wires on an FP motor yesterday, in hopes that it would get soldered quickly enough to not heat up the motor terminal so much that the plastic support would melt.
I guess we need to worry about the thermal limiter too ![]() |
#18
As always, your numbers will prove to be very close to the mark and a 40% operation point on the FP puts it close to it's optimum efficiency point (a bit more than 10%). The higher the motor efficiency, the less heat you generate... I would also note that the "chin-up" occurs at the end of the match and, coupled with the current draw of the motors, your battery voltage may not be optimal. Since power falls off as the square of the voltage, I'd be tempted to design for a two FP gearbox and de-populate the second FP after testing. This should guarantee success... JMHO, Mike |
#19
I think from the discussion, that the FP motor will trip the PTC if it is stalled, although, I have yet to see any test data. I would propose a test where the motor is stalled and voltage increased until the PTC trips to see what the max continuous current is (at least for the lab conditions) , except I don't want to risk a motor for the test. My hair dryer has tripped a few times when the dust builds up over the fan exhaust, but it has always recovered. I would hope the FP would recover too. Has anyone actually tripped an PTC yet? I really am not sure how to design a fixed roller that sucks up a ball to ensure a motor will not stall. It would seem that this requires limiting the normal force on the roller which is difficult when a ball is squished between a wall and a robot. Even with a frictionless back bar, it seems the ball can deform and push hard against the roller. If the roller is at all sticky getting a normal force equal to the output torque/radius doesn't seem too difficult. We are using a FP with a banebot 16:1, a 1.6 in dia roller. This can deliver about 30 lb of tangential force to the ball and getting a normal force 30/u_roller seems plausible for any reasonable u_roller. Squirrel and others seem to be able to spin the ball on the rug which implies u_roller>u_rug. Using a slippery roller can keep from stalling probably , but degrades ball magnet performance. So, we limit the normal force on the roller and actually shut down the motor when the normal force lifts up the roller. I still would be very happy to know if we do stall that the motor is not damaged. |
#20
Do you use this factor to modify the free current (free speed) on the output of the gear box? I generally don't, but I know the friction load will slow the free speed down. |
#21
Chris,
I haven't this year but have in the past. As the device is a bi-metal switch it returns to normal when it cools the same as the breakers. |
#22
WOW, this is one of the best and easiest to follow posts on this subject that I have ever read! Being an Electronics Engineer, this mechanical example goes a long way to explain to me how to approach this type of design. I do have have one question though. The following comment lost me, I would like to know where you came up with the 100N/m value? Quote:
#23
600N * .17m ~= 100 N-m Last edited by Vikesrock : 04-02-2010 at 18:52. Reason: typo |
#24
Thanks Vikesrock. (Dang, if I had just opened my calculator I might have figured that out... ) |
#25
PTC is wrong. Bi-metal is right.
Al has been kindly pointing that out several times, but I have planted a bad seed and it is growing. PTC is a kind of conducting plastic that has a positive temperature coefficient which is the secret sauce that allows it to be used as resetting breaker for current. Basically the more current it conducts the hotter it gets the hotter it gets, the higher the resistance (the positive coefficient, get it) the this causes more heat build up until you get a cascade where the resistance of the PTC is so high that it only conducts a very small amount of current that (hopefully) allows the fault to clear while the device it protects is kept from catching fire or melting or whatever. PTC's literally revolutionized the automotive electronics business about 20-25 years ago. BUT... ...at higher currents, PTCs become problematic. Bi-metal becomes more competitive at currents above 20-25Amps. Bi-metal is just what it sounds like two types of metal stuck together (usually not literally stuck together but they are more often hot formed together). When the strip of bi-metal gets hot, one metal expands more than the other so the strip bends. This bending action is used to open a switch contact. SO.... FP uses a bi-metal thermal switch to protect the motor. Please make a note of it. Joe J. P.S. Thanks to Al for his encyclopedic (wikipedic?) knowledge of all things FIRSTian. Last edited by Joe Johnson : 04-02-2010 at 19:54. |
#26
It won't perfect but FIRST almost never requires perfection. Build a simple predictor, tune in some parameters and viola! You can know if your rollers are on the edge of a nervous breakdown ;-) Cheers, Joe J. |
#27
The trip level could be as simple as a linear function of speed. So when running at speed "w" we set the trip at w/w_free*i_Stall+ delta where the delta is the safety current margin. When stalled , the motor would shut down if current was > delta. Of course there would probably be time elements involved. delta would probably be on the order of a few amps to 10 amps depending on the "allowed time to exceed the scheduled limit" criteria. Apologies to AL for not picking up on the bi-metal distinction. |
#28
This paper (Closed-Loop Motion Control for Mobile Robotics -- by Rich LeGrand available for $1.50) makes reference to the idea of using Back EMF to control a motor. The great thing about it is that you don't need to http://www.chiefdelphi.com/forums/ne...ly&p=913687put any extra stuff on the motor to get PID control. FYI, Rich LeGrand is from Charmed Labs which hosts this example video that dropped my jaw. If you want to learn more about how it works, look at this link from another cool robot website, Acroname.com. I think they really do a pretty good job of making the concepts understandable. Actually, Acroname.com is part of the way there already in that they offer an H-bridge with velocity feedback built in. So... I want to see this built in as a feature of the Jaguar. You could command motor speed for any motor on the robot! Think of the well behaved robots you'd see if the default code implemented velocity control as the standard method move a drive wheel? Need a beater bar to move a a standard speed without having the fuss an muss of adding a sensor and implementing a feedback loop? no prob. This would be a very big deal for FIRST robots. For your consideration. Joe J. |
#29
http://www.chiefdelphi.com/forums/sh...light=back+emf You probably were not hanging around CD when I started this thread else I'm sure you would have contributed then. Last edited by vamfun : 05-02-2010 at 18:24. |
#30
Again, this is PER stage, so... ...general use, I would say 81% effecient from motor shaft to output shaft (effective torque multiplier of 13). Mission Critical (for example, lifting a robot), I would use 72% (effective torque multiplier of 11.5). Callin' 'em as I see 'em since 1995... Joe J. |
| Fisher price motor | frcchile | Programming | 1 | 10-02-2009 11:04 |
| Fisher-price motor | team2061 | Motors | 14 | 09-02-2009 12:46 |
| Fisher Price Motor | Macdaddy549 | Motors | 5 | 28-04-2007 09:32 |
| Fisher Price Motor | Andrew Y. | Motors | 2 | 20-11-2006 07:52 |
| What Power Wheels car is the Fisher Price From? | sanddrag | Motors | 1 | 06-02-2005 17:53 |
