Go to Post Inspect every connection after every match. Use your eyes, ears and nose. - Al Skierkiewicz [more]
Unread 04-02-2010, 17:02
martinswat1806 martinswat1806 is offline
AKA: Zach Martin
FRC #1806 (SWAT Robotics)
martinswat1806 has a spectacular aura aboutmartinswat1806 has a spectacular aura aboutmartinswat1806 has a spectacular aura about
Re: lift winch ideas anyone?
We are considering meshing two fisher price motors and gear boxes. we used a similar design in 2007 and it worked well for us. a positive is that they are lightweight and still provide all of the power and speed you would need in a winch. Hope it helps.
Unread 04-02-2010, 19:33
lespie lespie is offline
FRC #1785
lespie is an unknown quantity at this point
Exclamation Re: lift winch ideas anyone?
we are using a hand wench and changing the hand part to the motor and i cant say much more so i cant tell you much more but try a hand wench that has gotten us this far........
good luck
Unread 04-02-2010, 22:01
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
a wench, that's pretty creative (and heavy) , we're using a steel-cable boat winch and a scissor lift
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 05-02-2010, 14:03
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Anybody know if you can get a winch like these locally, like a hardware store or Lowes/Home Depot?
Unread 06-02-2010, 05:50
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
2 CIM motors for our winch... Overkill? Maybe.
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Unread 06-02-2010, 19:32
Hastypickle's Avatar
Hastypickle Hastypickle is offline
AKA: Nicholas
FRC #1703 (Rats)
Hastypickle is an unknown quantity at this point
All I am saying about ours is that we are using a single CIM directly attached to the drum of a hand winch.
Unread 08-02-2010, 03:51
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
Thanks for the replies everyone! Great advice! So in response to the last reply, is a CIM powerful enough to drive a winch drum directly and lift the robot? I was thinking about a worm and worm gear setup to drive the hand crank shaft on a winch supplied by grainger.
Unread 08-02-2010, 15:15
joek's Avatar
not unless you use a gear box with it, we're using one from '07, but a worm gear might work
Unread 08-02-2010, 15:38
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Originally Posted by windell747 View Post
......So in response to the last reply, is a CIM powerful enough to drive a winch drum directly and lift the robot?.....
If the diameter of the pulley is about 1/48th of an inch. Then it must be made of some really strong stuff.....
Or it winds in a block and tackle with about 48 pulleys.....
I would suggest downloading and learning to use JVN Spreadsheet. http://www.chiefdelphi.com/media/papers/2059
Unread 08-02-2010, 19:55
AKA: Nicholas
FRC #1703 (Rats)
I forgot to put in that we are using a gearbox. Our tests show that our configuration will work quite well.
Unread 10-02-2010, 16:46
baihooli3022 baihooli3022 is offline
None #3022
baihooli3022 is an unknown quantity at this point
hey guys, what Team 3022 did for our winch system. We just basically used the KOP's Window motor, and placed a bearing on the other end of a shaft we fit into the motor. Next, just attach a string, and instant winch made by the KOP motors. We tested it earlier with just our bot's frame (about 40 pounds), and it worked fine. We're about to test it with our robot's near final weight (about 100-120).
Unread 10-02-2010, 17:39
joek's Avatar
a window motor is not gonna lift a robot without being geared down a lot
Unread 10-02-2010, 18:34
Electrical Engineer
Rookie Year: 1995
Joe,
OK. Let's see if the math supports your statement...
The previous poster stated that he connected a shaft directly to the window motor. The most likely would be a 3/8" diameter...
The spec sheet for the Nippon-Denso gives a stall torque of 10.6 N*m. Now, the maximum power for a DC motor will occur at 1/2 speed and this give a torque of 5.3 N*m or 3.9 ft*lb or 46.9 in*lb.
The radius of the shaft is 3/16" which gives us a lifting force of (16*46.9)/3 = 250 pounds...
Cool!
I will leave it as an exercise for the student to calculate the speed of the lift and as an exercise for the testers to determine if the internal PTC resistor will interfere with lifting operations...
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 10-02-2010, 19:36
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Can we use more than 4 CIMs? I forget what the rule is.
Thanks![/quote]
this year you are allowed to use up to five CIMs... We are using a 32:1 BaneBot Transmission with a CIM powering it, and it is hooked up to a custom winch system that we built... the one thing that you have to worry about is if you are using any type of airplane cord or such(anything besides an arm) than you will have to make some type of guide to stabilize the robot while you are grappling up.
Unread 11-02-2010, 20:33
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Our winch idea (already made now ) is here. Although, it is a bit overkill, since by my calculations, it can lift about 600 lbs... However, it can do it in about 3-4 seconds to get above the platform, and 10 to get to 7 ft. What you see in the model is a 12--->24, then a 1----->60 reduction. All in all, it is a 120---->1 ratio.
Want to buy a scissor lift for our cart, any ideas? Team1824 General Forum 1 02-03-2009 15:47
Scissort Lift vs. Crane vs. 4-Bar Lift vs. Gas Springs AdamC Technical Discussion 31 20-01-2008 18:49
Cable Ideas?? Anyone? Zak698 General Forum 2 14-08-2006 20:03
Winch edomus General Forum 43 21-02-2004 02:30
