Go to Post It doesn't always work when you put the word gracious in front of anything. Think Battle bots, after a winning match do ya go over to the loser and go we Graciously kicked your butt!? - Alex Cormier [more]
Unread 04-02-2010, 17:32
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
running solenoids with C++ code
Can we run the solenoids only using a digital I/O port? This would have to run through a spike to work (I think). Or can we also use a relay I/O port directly? The manual is kinda fuzzy on this point.
What is the best approach? Which class works best? And do I need a spike to run a pneumatic solenoid?
Unread 04-02-2010, 17:42
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Re: running solenoids with C++ code
Never mind - the solenoid class controls the NI 9472. The manual refers to digital I/O and it confused me.
cRIO Not Running Code?!? JohnFogarty Programming 11 17-01-2010 19:08
Running camera code wirelessly windell747 NI LabVIEW 4 09-02-2009 21:27
Issue with debugging/running code on cRio 114Klaatu0x72 Programming 5 27-01-2009 14:02
Problem running compiled code jskene Programming 10 23-01-2005 21:13
Controlling Solenoids With Victors Brandon_Cmpvir Electrical 20 16-03-2004 10:21
