Go to Post Basically, just because you CAN do something doesn't mean you should and being savvy enough doesn't entitle you to being above the law. - Greg Needel [more]
Unread 04-02-2010, 07:20
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Team 3038 Drive Train
This is our second year and we create a drive train that can pull and push a 120lbs man. If you like post comments, I will try to get more videos of it driving.
Here is one
Here is the second
any comments or questions just post here
Unread 04-02-2010, 08:36
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Team 3038 Drive Train
Here is one
Here is the second
Pretty cool.
A better test of pushing power though is setting up a scale against a wall, placing your robot in front of it and then pushing forward until the wheels slip or the motors stall. That will give you a quantifiable thrust.
What you showed in your video is that your robots thrust (weight x CoF) is more than the mans traction (weight x CoF) while on his butt
... But it is cool to see robots pulling people
___________________
- Tennyson, Ulysses
Unread 04-02-2010, 09:45
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Most robots will proboly weight 150 ish pounds and will be pushing back on you with as much or more force... Just saying.
Every day is a new adventure!!!
Unread 04-02-2010, 09:56
kwotremb's Avatar
kwotremb kwotremb is offline
FRC #3414
kwotremb is a splendid one to beholdkwotremb is a splendid one to beholdkwotremb is a splendid one to beholdkwotremb is a splendid one to beholdkwotremb is a splendid one to beholdkwotremb is a splendid one to behold
Back in 2003 (The challenge with totes) when the CIM were just starting out we had a robot that pulled a HD Truck with a larger trailer (Only 2 CIMS allowed). So these motors can pull quite a bit if geared right and there is enought traction.
2013: Team 3414 Hackbots
Waterford District: Finalist (51, 3604)
Livonia District: Winner (3641, 240), Spirit Award
MSC: 6th Seed Captain (862, 3641), Spirit Award
Worlds: Seeded 32 in Curie
Past Years:
Team 3414: Hackbots, 2013-Current, Mentor
Team 818: Steel Armadillos, 2008-2012, Mentor
Team 93: N.E.W Apple Corps, 2002-2003, Student
Unread 04-02-2010, 10:03
wow i think ours is still cool it looks BA with the side view i will try to get that pic
Unread 04-02-2010, 10:05
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
But they also had those 2 drill motors which I believe were more powerful than the CIMs.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 04-02-2010, 10:55
Yes those drill motors were pretty insane. Paired up with a CIM they easily pushed around 300lbs (weight of person + CoF) + when properly geared.
Unread 04-02-2010, 17:45
machetemonkey machetemonkey is offline
AKA: Nate
FRC #2491 (No Mythic)
machetemonkey is an unknown quantity at this point
...maximum weight limit 120?
I'm not sure where you're getting 150.
Anyways, pretty cool chassis; it's awesome to see it get that much strength, although as someone said, a wall-scale test would do best.
"No Mythical Creatures in My Classroom!"
-Myself
Yes, my dislike of twilight sparked the inside joke that created our team name. I feel special.
Unread 04-02-2010, 17:50
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
120 for the robot + 20 lb (max) bumpers + 15 lb battery
Unread 04-02-2010, 17:55
AKA: Nate
haha, forgot about that. Thanks for correction. >_>
-Myself
Unread 04-02-2010, 19:29
you still have to admit that we have a good drive train.
Drive Train Components: the inner working parts of a drive train naruto137 Technical Discussion 3 10-12-2008 21:14
pic: Team 1296 drive train Redo91 Robot Showcase 8 15-02-2007 00:01
pic: Team 11's Drive train CD47-Bot Robot Showcase 4 07-03-2004 21:40
pic: Team 60 Drive Train Parts CD47-Bot Robot Showcase 17 07-02-2004 01:58
