Go to Post How the mentors of a team inspire their team is unimportant, as long as the team is inspired to do great things. We on 1824 believe in 'student designed, student built', but that does not mean that all teams should do as we do. For inspiration comes in many forms. - Daniel_LaFleur [more]
Unread 03-02-2010, 17:37
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
Exclamation Wiring solenoids
We are looking at how to wire our solenoids to our solenoid breakout. We have the connections to the solenoid itself correct. However, we are trying to figure out how to connect the other end of the wires to the pins on the solenoid breakout (the one that is inserted into the slot on the cRio). Do we try to put the wires in the little white jumpers in the KoP and then the jumpers connect to the pins on the breakout or is there another connector we are suppose to be using?
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 03-02-2010, 17:40
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Wiring solenoids
With our solenoid we took a 3 pin PWM cable and connected 2 of the wires to the 2 wires coming from the solenoid. After that we cut the 3rd PWM cable off (The one we were not using) and connected it to the relay pins on the Pneumatics bumper/Solenoid Breakout. I think this is what you are asking... Sorry if I am wrong!
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 03-02-2010, 17:48
rsegrest's Avatar
Ok yes this is what we are asking but what do you mean when you say...
Where did you connect them? Did you twist the wires together and then use wire nuts or did you somehow jam them into the connector itself?
~ Unknown
Unread 03-02-2010, 21:02
The KOP came with a bundle of 2-pin cables.
Cut one of these in half and you have two connectors suitable for connecting solenoids to the Solenoid Breakout.
Unread 03-02-2010, 22:01
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
That would be the correct way of doing it, I guess my electrical members are too lazy to find those cables, and somehow making new ones are easier. Good luck with your solenoid!
Unread 04-02-2010, 18:02
rsegrest's Avatar
Can someone post a pic of what we're talking about? I am a visual learner and it would be really helpful...
Thanks!
~ Unknown
Unread 04-02-2010, 18:40
The 2-pin cables are gray and have female connectors on both ends.
They are the gray cables all the way in the bottom right of this photograph
http://team358.org/files/programming...trolSystem.jpg
Unread 04-02-2010, 19:54
rsegrest's Avatar
Found the gray cables. Thanks for the help!
~ Unknown
Unread 06-02-2010, 16:39
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
Exclamation Re: Wiring solenoids
It would still be nice to have a complete diagram of which side goes where, and if the cables on both ends have to be twisted together, etc. Is there such an image to see what it would look like on the bench?
Thanks
PS We have the new Festo valves, and I think the valves have to move in unison, right?
Unread 23-02-2010, 14:00
dan_h dan_h is offline
EE Grad Student
AKA: Dan Huizenga
#0518
dan_h is an unknown quantity at this point
<rant>
Don't call your mentors lazy - they're there as volunteers. If you really want the cables, and your mentors are too busy to find them, go look for them yourself.
</rant>
Team 518 Home Page
Unread 23-02-2010, 22:37
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by dan_h View Post
<rant>
</rant>
He did write "members", as in 'team members', at least that's how I read it. FWIW
Re-wiring 24V double solenoids almsfan21 Pneumatics 2 30-01-2007 14:35
wiring solenoids Brawler006 Electrical 10 22-02-2004 21:06
# of solenoids Brawler006 Pneumatics 5 01-02-2004 11:12
solenoids hot69z Electrical 2 08-01-2003 06:02
Solenoids archiver 2001 9 23-06-2002 23:47
