Go to Post This easy world of friends, of people that you can talk to for hours on end without knowing one another? That's FIRST. - Keith Chester [more]
Unread 04-02-2010, 16:54
glitch glitch is offline
FRC #1596
glitch is an unknown quantity at this point
labview delay help
hey, im relatively new and im using the classmate so pardon my grammar. im using labview to program our teams robot (1596!) and i need help with our camera tracking. ive recently learnt how to track the vision target but i need help because our camera (mounted on two servos) overshoots the target, is their any way we can adjust how fast the servo moves so that we dont overshoot the target.
Unread 04-02-2010, 18:32
hamosad1657 hamosad1657 is offline
FRC #1657
hamosad1657 is an unknown quantity at this point
Re: labview delay help
Hello 1596,
For adjust the servo moves, try to use the PID calculation that will smoothing the servo motion, or just lower the tracking rate.
Unread 07-02-2010, 23:17
bls0620's Avatar
bls0620 bls0620 is offline
FRC #0368 (Team Kika Mana)
bls0620 will become famous soon enoughbls0620 will become famous soon enough
If you are running the program off from any laptops instead of running the program as start-up, they WILL be some delays.
Unread 08-02-2010, 09:37
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Keep in mind that while your typical Teleop loops are running at 50 Hz, the default code's image processing can maybe squeeze out 10 new target updates per second ... and as low as 2 per second when the camera is set to its highest resolution. (I'm referring to the default code here)
My team used the front panel from the FindCircles VI to observe almost 500msec when the camera is set to Hi-Res. Around 250 msec at medium res. And around 150 msec for low res. You can improve these times by changing the search window etc., but it's important to understand the timing differences of the control system, and the target detection updates.
For the medium-resolution example, if you control the servos from within the Teleop VI, then you'll have approximately 12-13 "drive" cycles for each target update (250 / 20). So if you are adding an offset angle to the current angle, you'll probably overshoot the target unless the delta-angle is very very small.
Our first attempts would overshoot greatly ... we reduced the delta "bump" angle to as low as 0.55 degrees per "correction" and finally got it to lock. (smaller values would result in the camera not even moving)
Our next improvement to our tracker will probably involve taking the control commands out of the teleop vi and placing them with the other parallel tasks, and also waiting for the target variable to update before acting again.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Labview help pedro696 General Forum 14 06-02-2010 19:34
LabView Help Please NumBeast NI LabVIEW 3 19-12-2008 15:11
Delay Help! waiakea2024 Programming 7 21-02-2007 12:41
help: cannot get the picture in the labVIEW program .. (was: need help!! quickly!) liad LabView and Data Acquisition 8 18-01-2006 12:20
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
