Go to Post Mentors: Don't give up folks, your efforts are not in vain. The kids get something out of it whether we get acknowledgment or not. - Swampdude [more]
Unread 04-02-2010, 18:45
K Lenox's Avatar
K Lenox K Lenox is offline
I AM GOD IN GEARS OF WAR!!!!
FRC #2632 (Comets Unleashed)
K Lenox is an unknown quantity at this point
Changing constants to variables in LabVIEW?
Hello, I am Kyle Lenox of the Amherst Robotics team.
I was wandering if there is a way to change the constants to varibles in labVIEW. The idea is that if the constants were varibles, you could take less time building and running the LabVIEW data.
Or, if there was a way to change the iputs on the dashboard. By doing this you could edit speed controls, legth of time, (etc.) and not hace to shut down the Dashboard, open up LabVIEW, edit the code, build it, run it at start-up. If that is possible please let me know!!
Thanks, any bit of know-how is appreciated!
Kyle Lenox
Team 2632
[font="Times New Roman"]
You never saw this message
You never read this
You will read the next available object within sight
Why are you still reading this???  Begone with you!!!
[SIGPIC]
Unread 04-02-2010, 18:47
hamosad1657 hamosad1657 is offline
FRC #1657
hamosad1657 is an unknown quantity at this point
Re: Changing constants to variables in LabVIEW?
Just right click on the input of VI, ->Create->Control.
Good luck!
Unread 04-02-2010, 21:11
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
After you turn them into controls and edit their values during debug, make sure that you go into the edit menu and select "make current values default" so that the values stay when you download the final code.
Twitter Profile
Unread 04-02-2010, 22:18
All good suggestions. You can also right click on a constant and Change to Control.
Greg McKaskle
[FTC]: Help with LabView and variables? cougarbytes FIRST Tech Challenge 2 29-12-2009 15:57
HELP!!! BOOLEAN VARIABLES IN LABVIEW PRAWG Programming 2 07-02-2009 18:44
Making global variables in LabVIEW. Joshamuffin National Instruments LabVIEW and Data Acquisition 1 19-01-2009 13:35
[FTC]: Variables in labview wilsonmw04 FIRST Tech Challenge 2 23-11-2008 08:57
Labview dashboard and multiple variables Joe Ross LabView and Data Acquisition 2 15-03-2006 21:55
