Go to Post For those of us in the north, a water game turns into an ice game, which becomes Lunacy. And I don't think any of us want that. - Kimmeh [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 04-02-2010, 10:54
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Re: ofstream (standard C++ file output) not working
Right, so if it is called before fopen() in the same thread, why would there be a race condition?
I think we're having some kind of communication disconnect. Sorry.
  #32   Spotlight this post!
Unread 04-02-2010, 13:08
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
You would not. The situation described above (or how I read it anyway) was that you were not calling Priv_SetWriteFileAllowed, and that it sometimes worked. I was suggesting that there are other tasks that may be calling it that would allow the write to work sometimes and not others.
If what you are saying is that you are calling it in the same task before the fopen and it still only works some of the time, then I don't have a good theory for you. Let me know if this is the case and I'll try to look into it a bit more.
-Joe
  #33   Spotlight this post!
Unread 04-02-2010, 15:20
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
A race condition would make sense, originally, I had the write in the simple template constructor, later i put it in the auto. I will test out the race condition today. My plan:
write to file in entry point function before anything else
write to file in robot constructor
write to file in robot auto after 10 second wait
they will be tested 10 times without priv_set..., and 10 times with priv_set...
I will report back later
Watchdog.Kill();
  #34   Spotlight this post!
Unread 04-02-2010, 19:09
byteit101's Avatar
Hmm, I am not seeing any blocked attempts to write; Every test was successful, without the priv_set... Sometimes it took up to 10 seconds to find it over FTP, but every test was successful
Watchdog.Kill();
  #35   Spotlight this post!
Unread 04-02-2010, 19:12
Make sure your FTP client is not caching the directory listing. What client are you using?
  #36   Spotlight this post!
Unread 05-02-2010, 06:29
byteit101's Avatar
FileZilla
Watchdog.Kill();
  #37   Spotlight this post!
Unread 05-02-2010, 15:40
FileZilla
Hmm... should be fine as long as you refresh and are connected. Have you tried putting prints to go along with your writes to get some idea of when the write happened vs. when you see the file on the FTP server?
  #38   Spotlight this post!
Unread 05-02-2010, 15:49
byteit101's Avatar
no, but I think it might be the code is slow (I only immediatly looked at the folder for a few test), you hit Run kernel task and it downloads, (I was measuring from that point), it calls the entry point function, and inits everything before creating the file
Watchdog.Kill();
  #39   Spotlight this post!
Unread 05-02-2010, 18:27
davidalln's Avatar
davidalln davidalln is offline
World's Worst Coder
AKA: David Allen
FRC #2415 (The Westminster Wiredcats)
davidalln is on a distinguished road
Send a message via AIM to davidalln
We finally got our log working consistently (although not as sophisticated as 3132's Logger, it's a foundation in which stuff can be added on). It looks like the race condition problems listed above were the culprit. The key is not to completely overwhelm it with added lines in the main loop.
We have wrapped it in a class if anyone's interested: http://gist.github.com/296373
SANTOSH ANDREW DECKER RICK WYNNIE SEAN DEREK MATT
(alamo (semis), p'tree (CHAMPS!), nc (CHAMPS!), newton (quarters))
Best four years of my life. Thanks to everyone who made it happen.
p2 not working? Lone_Wolf92c Programming 5 22-02-2008 08:49
IR Board Not Working (But NOT Fried) itsme Electrical 2 18-02-2008 06:11
Beware - transmission output shaft is not 5/8"! jskene Kit & Additional Hardware 30 13-02-2006 14:01
Drive() Not a Standard Toolset in EasyC? Chris_Elston Programming 3 08-02-2006 09:01
Beware - transmission output shaft is not 5/8"! jskene Technical Discussion 3 19-01-2006 14:24
