Go to Post You know, if I was John V-Neun I would get a copyright on my name! - Jay H 237 [more]
Unread 04-02-2010, 14:39
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Re: AndyMark Nano Break In
This is an excellent thread with good information. Thanks for contributing!
As far as "how long to run a gearbox in?" I would say the conditions listed bt Sanddrag for current draw are good. We have typically run KOP Toughboxes for 15 to 25 minutes before getting to those current levels. be sure to monitor motor heat and listen for odd noises that could indicate an assembly problem. Monitoring your current draw with a benchtop power supply is very helpful.
Good luck!
Rob
Unread 04-02-2010, 15:10
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Using a Black Jaguar and BDC-COMM can make breaking-in a gearbox quite easy.
Set your motor to run at a specific voltage in voltage mode, or a specific speed in speed mode (with an encoder), and then monitor the motor current values it spits out. Just like on TV, set it, and forget it! (but not really, be safe and keep an eye on things)
-David
Unread 04-02-2010, 17:09
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
here are some photos I've taken of the two issues discussed about the Nano gearboxes. First is our issue with the bearing sticking out and getting in the way of the motor mount, we were able to fix this easily. The second picture shows the slack in the gearbox with the big washer that comes installed.
http://twitpic.com/11e1jk
http://twitpic.com/11e1o6
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 04-02-2010, 17:12
CraigHickman
Posts: n/a
Originally Posted by sanddrag View Post
I've done break-in on a number of FRC gearboxes over the years, and let me tell you, it makes a big difference. When running properly, a typical gearbox like the Nano should draw between 2.3 to 2.8 Amps per CIM with no load, from a 12 Volt supply.
Yours are drawing too much. You have something binding.
One year, I had a tight running gearbox, and no way to remachine the plates to increase center distance, and no lapping compound available. I took a bottle of car polish and poured it right in the meshing gears. A few cycles of this, and 20 minutes later, and a bunch of cleanup, and it ran like butter and current draw was less than half of what it started at.
For those of you designing your own gearboxes, make sure to use precision ground bearings. I've seen teams build gearboxes with non-precision general purpose bearings, that just aren't rated for the loads or speed they see, and they fail. I've even seen sloppiness in brand new bearings cause a gearbox to bind enough to nearly stall a CIM.
Do you break your gearbox in with any sort of lubrication or abrasives? We usually just dump a glob of lithium grease onto the gears during break in, but I'm curious as to how others go about this process.
Unread 04-02-2010, 19:09
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Jonathan,
You say you fixed the bearing pushing out easily...was with the AM trnasmission I could see how you might make room. How do us CIM folks do it though?
Unread 04-02-2010, 19:14
AdamHeard's Avatar
Lead Mentor
Does anyone know a good way to get current draw using a voltmeter and ohms law?
Unread 04-02-2010, 20:59
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Grease is to prevent wear. During break in, you want to wear the gears into each other, not to prevent it. An abrasive compound is usually used for this. I would not grease the gears if the intent is to wear them in. However, once worn in, I would recommend always keeping the gears greased to prevent further wear.
For 968, we have not had to do any specific break-in procedure on our gearboxes in recent years, since we add a couple thousandths extra center-to-center distance.
Unread 04-02-2010, 22:20
DonRotolo's Avatar
Back to humble
FRC #0832
Yes, of course. I=V/R, right?
So, carefully measure the Resistance of a piece of wire (I think #10 is 0.1 Ohms per foot, but check me on that. Measure several feet, accurately, being sure to subtract the resistance of the test probes). Now you know R
Measure Voltage across R while the motor is running, and do the math to solve for I (in Amperes)
Note that even a small error in R can lead to large errors in I, but this is also good for relative measurements (as in "it's drawing half the current it was drawing before")
Unread 04-02-2010, 22:27
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
We use a clamp on ammeter when just running DC off a battery. We also use a current shunt such as this one: http://www.powerwerx.com/tools-meter...0-amp-max.html It's just a calibrated resistor. You then put your voltmeter across it and measure millivolts ...1 mv per amp.
Al Skierkiewicz posted something a while back about using something like 1 ft of #10 wire also dropping 1 mv per amp. Of course it's not as accurate as a calibrated current shunt (above) but it would certainly be fine for breaking in motors. You just measure the voltage across that length of wire in series with the motor wires.
Unread 04-02-2010, 22:34
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
Originally Posted by Dale View Post
Jonathan,
If you contact Andymark, you should be able to get the replacement bearings that mount flush... another possibility is to grind down the corner of the motor a bit (but i dont reccomend this method, it may classify as modifying the motor.) Number one quick fix i recommend is just to put a washer between the cim and the nano. it should fix the problem
Unread 04-02-2010, 23:06
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Samir is correct, contact AM for the correct bearing. Temporarily you can use washers but I wouldn't' do that in competition.
Unread 05-02-2010, 00:07
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
The Nano we just recieved actually had interferance between the internal hex of the output shaft and the first stage gear. They were literally hitting each other and locking up. We had to remove the output shaft and sand off the corners of the hex to free it up. Make sure you don't have this problem, although I'm sure you would know it if you did. Is it noisey? (Noisier than usual that is.)
Unread 05-02-2010, 13:27
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
You are all correct. Andy Baker suspects that what's happening is the thicker shielded bearing (a FR6ZZ) when clamped down by the bolts holding it in for that axle, is causing things to bind internally and the current to go through the roof. The thinner unshielded bearing, a FR6 (http://store.andymark.biz/am-0027.html) is what's needed.
Unread 08-02-2010, 15:51
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Just a quick update on two observations after receiving our NANOs over the weekend.
First, we used a 5/8" retaining ring to fill the "wiggle" on the last stage output shaft. It slipped right over the hex shaft and was the perfect thickness to reduce the wiggle but still be free of binding.
Second, we noticed that there is also a little slop in the first 50 tooth input gear that the CIM pinion mates with. This was causing the gear to contact the two washers on the CIM shaft for positioning the pinion. This caused significant binding and may be the cause of the high current draw that some people have observed. The solution was to assemble the CIM pinion with only one washer behind it.
After assembly we ran in for 15 minutes and the gearbox was humming along with the CIM only drawing 2.4 amps!
We are direct driving our kicker off of the NANO and have made many kicks so far with no signs of wear or tear. The thing works beautifully!
Rob
TB Nano Encoder Spacing daltore Kit & Additional Hardware 5 24-01-2010 11:17
pic: AndyMark has the Nano; we have the Shuffle! rob_c Extra Discussion 10 19-01-2010 22:30
pic: I love the nano Akash Rastogi Extra Discussion 6 02-11-2009 18:19
Lost iPod Nano - SVR Otaku General Forum 0 02-04-2007 21:20
