Go to Post FIRST is similar to real life in that nothing is perfect and you have to deal with the circumstances as they arise and make the best of it! - Sean_330 [more]
Unread 04-02-2010, 22:04
Re: Inverted Turning
Originally Posted by Darkknight512 View Post
It doesn't seem to make sense to me that the robot goes backwards when the PWM's are switched.
Think about which way the motors turn in order for the robot to move forwards. Drivetrain designs with both motors going the same direction are vanishingly rare. Almost invariably, one spins clockwise and the other spins counterclockwise.
When you swap the motor control, you're telling each motor to turn the way the other one used to. That runs the robot in the other direction.
Just look at the code, and at the robot wiring, and make sure that the PWM signal configured as the left motor is the same one physically connected to the left motor. Do the same for the right motor. Then if either side of the robot runs in the wrong direction, invert that motor's control in the code.
Setting inverted motor help kiettyyyy C/C++ 1 14-01-2009 19:09
pic: lego inverted pendulum colin340 Extra Discussion 6 01-02-2007 14:56
Inverted color mind tricks! thegathering Chit-Chat 19 31-08-2006 18:05
Camera Picture is Inverted winners Programming 2 27-01-2006 20:09
IR signals inverted Atheist Electrical 10 08-02-2004 16:27
