Go to Post People do amazing things for stuff the have a passion for. - Foster [more]
Unread 04-02-2010, 22:34
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
Re: AndyMark Nano Break In
Originally Posted by Dale View Post
Jonathan,
You say you fixed the bearing pushing out easily...was with the AM trnasmission I could see how you might make room. How do us CIM folks do it though?
If you contact Andymark, you should be able to get the replacement bearings that mount flush... another possibility is to grind down the corner of the motor a bit (but i dont reccomend this method, it may classify as modifying the motor.) Number one quick fix i recommend is just to put a washer between the cim and the nano. it should fix the problem
TB Nano Encoder Spacing daltore Kit & Additional Hardware 5 24-01-2010 11:17
pic: AndyMark has the Nano; we have the Shuffle! rob_c Extra Discussion 10 19-01-2010 22:30
pic: I love the nano Akash Rastogi Extra Discussion 6 02-11-2009 18:19
Lost iPod Nano - SVR Otaku General Forum 0 02-04-2007 21:20
