Go to Post Patience is a good strategy. - Koko Ed [more]
Unread 04-02-2010, 19:11
Jonanin Jonanin is offline
AKA: Jon Morton
FRC #1306 (BadgerBOTS)
Jonanin is infamous around these parts
Send a message via AIM to Jonanin Send a message via MSN to Jonanin
Camera Lag
Hello,
We are using C++ and using the AxisCamera class to control our camera. Right now, all we do with it is set the resolution to 160x120 and set the brightness to 0.
However, when we run the code, the camera display on the driver station lags EXTREMELY badly, usually 5 seconds or so (sometimes more), and skips a bit too.
Does anyone know what could be causing this problem or how it could be fixed?
Unread 04-02-2010, 22:47
Re: Camera Lag
See this post.
Unread 05-02-2010, 02:44
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Camera Lag
The posted C++ update should fix the lag that you are seeing.
Unread 05-02-2010, 11:29
AKA: Jon Morton
Re: Camera Lag
Well, after much trial and error, these are the steps that helped use get LIVE video finally. The post by Greg about doing less on cRIO does not seem to apply to robots programmed in C++.
1. Get the latest C++ update, make sure it is installed correctly.
2. Make sure the Driver's Station update installed the top half part correctly (it didn't the first time)
3. Apply the graph removal patch (link)
Finally, we now have live video.
2010 FRC Camera Live Feed Lag ideasrule Programming 23 11-02-2010 02:33
Camera lag...again ideasrule Programming 5 02-02-2010 13:09
Camera lag solution ringo115 Programming 11 31-01-2010 22:05
Camera Lag tutkows1 Java 1 27-01-2010 00:20
Camera Lag jmanela NI LabVIEW 6 25-12-2009 08:48
