Go to Post If it were not about winning, it would not be called a competition - but FRC is much more than winning a competition. - JaneYoung [more]
Unread 04-02-2010, 23:21
DarKCroNo's Avatar
DarKCroNo DarKCroNo is offline
FRC #2670
DarKCroNo is an unknown quantity at this point
AXIS CAMERA HARDWARE SETUP
I'm not sure about this, however I'm wondering is the camera setup DIFFERENT from last year? We are using the same setup, which is using the SERVO motors. I'm wondering are we suppose to use that again? because in the program it talks about using a gyro and no values concerning the PWM connectors where the servos went. So if it HAS changed, I'm wondering how its set up? Do we juts mount the camera and place a gyro on the robot itself?
Unread 04-02-2010, 23:31
Re: AXIS CAMERA HARDWARE SETUP
In LabVIEW, at least, the provided code for this year runs the drive motors to spin the entire robot. It uses the camera to determine how far to turn, then uses the gyro to know when it has turned that much. The camera seems assumed to be mounted to the robot in a fixed location.
Unread 04-02-2010, 23:35
DarKCroNo's Avatar
FRC #2670
Ohh i see, thank you!
Would you be able to provide help on another thread I've posted? it's about programming in C++
http://www.chiefdelphi.com/forums/sh...ad.php?t=81922
Java/Netbeans Camera Code for Classmate PC and Axis Camera joshholat Programming 1 23-01-2010 14:59
Help: "Setup Axis Camera" sloteera Programming 9 16-01-2010 00:59
Camera Setup ExarKun666 Control System 10 25-02-2009 19:18
Can't figure out the Axis camera setup... 2829ron Technical Discussion 6 20-01-2009 13:12
Setup Axis Camera - ERROR Bruno Inácio Technical Discussion 2 16-01-2009 12:37
