Go to Post And trust me, the very last thing you want to see is me with time on my hands and access to power tools. - dlavery [more]
Unread 04-02-2010, 23:40
Al3+'s Avatar
Al3+ Al3+ is offline
ARTist
AKA: Anthony
FRC #0840 (Aragon Robotics Team)
Al3+ is a jewel in the roughAl3+ is a jewel in the roughAl3+ is a jewel in the rough
Help with dashboard packing...
Alright. So I modified the dashboard and removed everything from it except the camera image and the robot IP (which was needed for the image to show). Then I added a single boolean indicator, and put this in my code:
Dashboard *dash;
void SendDashboardData()
  dash = &DriverStation::getInstance()->GetHighPriorityDashboardPacker();
  dash->AddBoolean(true);
  dash->Finalize();
And I call SendDashboardData() on each iteration inside OperatorControl. However, when I try to run this, it doesn't work, and sometimes causes all sorts of problems by freezing up the driver station.
What's the proper way to do this? I've looked at the DashboardDataFormat.cpp example but it seems to be written for the default dashboard with all the clusters on it.
Also, what's the difference between the high and low priority packers? Can they be used interchangeably?
cout << "Hello, robotics. Goodbye, world." << endl;
"The two-axis accelerometer provided in the kit of parts (shown in the picture below) is a two-axis accelerometer." - WPILib User's Guide
Unread 05-02-2010, 02:17
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Help with dashboard packing...
Dashboard *dash;
  dash->Finalize();
Freezing up the driver station? What makes you say that? Will the Tabs not switch? What exactly is the behavior?
It was written to match... and they have to. If you pack 1 boolean into the high priority, for instance, then you need to unpack 1 boolean from high priority on the dashboard side.
The high priority will be sent even if there are errors to report to the driver station. Low priority will not be sent if there is no space because of errors to be reported. Also, If there is not enough space for high and low priority, then only high priority will be sent.
They can be used interchangably, as long as you interchange them on the dashboard side and the robot side at the same time.
-Joe
Unread 06-02-2010, 01:34
Al3+'s Avatar
ARTist
AKA: Anthony
Yes, some time after the robot starts, the tabs and buttons stop responding to presses, and I can't do anything. The only way to get out of it is to reboot or to end it with Task Manager.
I'm not sure whether it's directly connected to the dashboard problem, but it stopped happening after I commented out the code.
Maybe I should upload my dashboard file.
Dashboard Help C++ Windriver ranc Programming 0 15-01-2010 15:26
Monitering C++ Code With A LabVEIW Dashboard Happyisgood C/C++ 6 14-07-2009 17:23
Help with connecting default dashboard project mminutto NI LabVIEW 2 30-01-2009 15:26
Packing for FL archiver 2001 4 24-06-2002 01:58
