Go to Post Adding an ounce or two of shields is way easier than filling out the mountains of paperwork for that one impatient person to stick their arm into the robot reaching for who knows what only to have their fingers meet up close and personal with a gearbox. - artdutra04 [more]
Unread 04-02-2010, 23:55
offramp13 offramp13 is offline
FRC #1425
offramp13 is an unknown quantity at this point
Analog Input tied to Accelerometer on Cypress
I've set our driver station up and installed the mandatory update. Now I'm trying to get all the I/O ports confirmed working. I used the PSoC Programmer to load the "FRC_IO.v2.hex", but I have run into a problem. The 8 analog ports displayed on the FRC Driver Station in advanced mode fluctuate with acceleration in the Z axis.
I am not sure if this is a configuration problem or if it is a problem with the hex code itself. Has anyone run into something similar to this?
Thanks in advance.
Unread 04-02-2010, 23:56
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Analog Input tied to Accelerometer on Cypress
Thanks in advance.
Do you have anything plugged into the analog inputs when this is happening?
Unread 05-02-2010, 02:40
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Yes. I've run into this. Although it's not anything to "run into", per se. Because the inputs are high impedance, if you have no source wired to an input, then the previous input voltage will still be lingering around in the sample and hold capacitor. Because the accelerometer and the analog inputs are on the same analox mux, you will see the last channel of the accelerometer (Z) on the analog inputs.
Nothing to worry about.
-Joe
Analog Input Errors... Tach'ko Electrical 1 11-01-2008 11:37
HELP: analog input Tottanka Programming 19 18-02-2007 19:27
Accelerometer: Analog or Digital? psquared Programming 2 10-02-2005 16:38
Accelerometer Wiring/Input DAN THE MAN Control System 1 06-02-2005 20:02
Analog Input Trouble Matt Krass Programming 10 20-01-2005 21:09
