Originally Posted by offramp13
I've set our driver station up and installed the mandatory update. Now I'm trying to get all the I/O ports confirmed working. I used the PSoC Programmer to load the "FRC_IO.v2.hex", but I have run into a problem. The 8 analog ports displayed on the FRC Driver Station in advanced mode fluctuate with acceleration in the Z axis.
I am not sure if this is a configuration problem or if it is a problem with the hex code itself. Has anyone run into something similar to this?
Thanks in advance.
Do you have anything plugged into the analog inputs when this is happening?
