Go to Post What language does your programming mentor have the most experience with? That's the language you should use. - Rosiebotboss [more]
Unread 04-02-2010, 22:23
Nwb code monkey Nwb code monkey is offline
FRC #1852
Nwb code monkey is an unknown quantity at this point
Lost in every sense, no errors, no clue
Ok, so, this may be the most mindless post here, but im a first year programmer, and our teams other programmer is in the same position as I am; neither of us know what anything is.
No one on our team knows how to get the programming to the robot, we dont know what cRIO is, we dont know if we have to program on the small laptop provided in the kit, we dont know how to connect the small laptop to ours to transfer code, we dont know how to assemble or assign ports or even what they are, we are utterly clueless, any help on any of this would be very much appriciated
We do know how to program (vaguely, we started learning JAVA febuary 3rd, but we are very fast learners)
Also, has anyone else noticed the lack of guides or samples on youtube or google?
Unread 04-02-2010, 22:29
adamdb adamdb is offline
adamdb has a spectacular aura aboutadamdb has a spectacular aura aboutadamdb has a spectacular aura about
Re: Lost in every sense, no errors, no clue
Sounds like you need to find another team in the Phoenix area to help. Come on Phoenix teams, this is what FIRST is all about!
If all else fails, make a plea to Ryan Clark, one of the professors at University of Advancing Technology in Tempe. He probably has a dozen robotics students that would love to help.
Adam Bryant
Programming Mentor
Team 1583
Ridge View Academy Rambotics
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
First if I may mention, and I mean no offense, but you are WAY behind and there are a bunch of FIRST manuals you need to look through check all of these links:
PS: that small laptop you are talking about is called the Classmate PC
These links are all gathered from this webpage:
http://usfirst.org/roboticsprograms/....aspx?id=10934
Control System Introduction
http://usfirst.org/uploadedFiles/Com...Rev-0.5%20.pdf
Control System Bench-top test
http://usfirst.org/uploadedFiles/Com...ed-Rev-0.7.pdf
FRC Java Manual provided by WPI
http://first.wpi.edu/FRC/frcjava.html
MANDATORY UPDATES:
Labview update for driverstation
http://joule.ni.com/nidu/cds/view/p/lang/en/id/1534
driverstation update
http://joule.ni.com/nidu/cds/view/p/lang/en/id/1535
Fix for the Driver Station missing nicyapi.dll Issue
http://decibel.ni.com/content/docs/DOC-8891
CAN/Jaguar update
http://first.wpi.edu/FRC/frcupdates.html
Hope this helps a little bit!
Also the cRIO looks like this:
Connect a Crossover Ethernet cable from Port 1 on the cRIO to the network input on the Classmate PC, or the PC you are programming on to upload code, or run your robot.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 04-02-2010, 22:32
FRC #1852
Thanks to both the posters above, we are checking the links now, and we will try to get ahold of another team, we might be behind, but im sure we can catch up XD
So I understand what cRIO is and I understand what Classmate is, reading now about cRIO imaging tool and all that...
Last edited by Nwb code monkey : 04-02-2010 at 22:51. Reason: Dont want to bump my thread
Unread 04-02-2010, 23:38
FRC #1852
Still need help, should this be in a different forum, such as technical or java?
Unread 05-02-2010, 00:14
3286's Avatar
3286 3286 is offline
AKA: mike s
FRC #3286 (the Rock-It surgeons)
3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of
Not wanting to step on toes or open a can of worms, we felt a bit helpless when it came to the entire realm of programming and all that. After some time and some searching its starting to come toghether.
Having said that, the one thing that I found would have been helpful would have been some type of generic, overall flow chart or diagram of what was communicating to what and an overview of the sequence of how things interrelated.
Some of it was just oversight and being a bit overwhelmed at the scope of what we had to do and what to do first, this is where more clarity would have been very helpful.
Its doable though, hang in there , theres tons of people out here who are willing to help out.
Mike
Unread 05-02-2010, 00:27
Tom Line's Avatar
Tom Line Tom Line is online now
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Mike, I have to admit that's where I struggled the most too a year ago when they first introduced the labview framework. The best thing I did was have the kids create a flow chart showing how the robot would move through the different modes.
Unread 05-02-2010, 00:45
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Download the java docs and look at the sample code.
Sample code is under New Projects -> FRC -> Simple Robot Demo
If you use ctrl + space in NetBeans it almost programs itself. Example: "Joy" + ctr + space will allow you to select Joystick and will add the necessary import for you to use the joystick class.
Unread 05-02-2010, 02:44
FRC #1852
Anyone wanna show me one of their flow charts, i just need to know what our boards should look like, with the jaguar motor controls, the motor controller, and cRIO and stuff
Unread 05-02-2010, 03:09
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
FIRST conveniently provides such documentation.
The Power Distribution Diagram should show you how to power everything.
The Data Connectivity Diagram should show you how the data wires (PWM, ethernet, etc.) are connected.
If you have any specific questions about these diagrams or how to wire things up, feel free to ask.
Unread 05-02-2010, 08:29
Did FIRST include a chart like this one from 2009?
It's only a high-level overview. The driver station is the Classmate now.
Unread 05-02-2010, 09:09
Electrical Engineer
Rookie Year: 1995
Mark,
I have not seen one. Pity... It would have been helpful to rookie teams...
Mike
Mike Betts
As easy as 355/113...
why does every one get mad over spelling errors. FlyingDutchman Chit-Chat 17 09-02-2007 12:47
My Movie Sense is Tingling! George A. Chit-Chat 22 05-07-2004 23:45
Stang-Sense Aaron Lussier Technical Discussion 16 17-01-2003 10:02
current-sense amplifier s_alaniz Technical Discussion 1 30-01-2002 07:42
