Go to Post You know what they say, the mind is the second thing to go and I can't remember the first. - GaryVoshol [more]
Unread 05-02-2010, 00:41
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: New Accelerometer and LabView
Originally Posted by Error code -44095
The I2C sensor identification string did not match. The expected sensor is not at the address and bus specified. The sensor was expected to return "Address: 58" but instead returned "Sensor did not respond."
I2C.lvlib:Read.vi>>I2C.lvlib:Open.vi>>ADXL345 I2C Open.vi>>i2c accel.vi
<time>06:23:27 02/05/2010
<unique#>1
Any ideas why this might be? I double-checked the wiring. I even checked the code to make sure it had the right address.
-- Marshal Horn
Unread 05-02-2010, 00:48
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Triple check the wiring? It's usually cause by a wiring issue. Do you happen to have a logic analyzer that you can use to look at the bus?
Unread 05-02-2010, 00:53
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
No, I just have an O-scope. (I don't think it'd show me much in this case, or I would use it)
The battery was low, so I put the bench-test on an external 13v supply. No change in response.
Should I try running a Driver Station, to see if that makes a difference?
I guess this brings up the other question:
How easy is this board to fry from heat or static electricity?
-- Marshal Horn
Unread 05-02-2010, 15:15
Well... if you can watch the data and clock lines you can check that the address is being sent correctly and that the address is actually not acked.
The driver station should not need to be connected as long as your code is getting called. Never hurts to have it, though. One less variable to worry about.
No idea... I've never seen one die.
KoP Gyro and Accelerometer Placement DavidB Electrical 6 05-02-2010 09:18
New TipJar Training Video - Autonomous Mode and LabVIEW Training Giveaway LVMastery NI LabVIEW 3 28-01-2009 07:06
New LabVIEW TipJar Tutorial Video: Scalability, Modularity and Style. LVMastery NI LabVIEW 0 18-01-2009 14:56
LabVIEW Training and new control system demonstration 10/17-10/19 in Frazier Park, CA Joe Ross NI LabVIEW 0 25-09-2008 13:25
gyro and accelerometer problems paulcd2000 Programming 6 16-02-2008 15:17
