Go to Post What happens when everything becomes fully swagged out? Also, does my robot need to have collar-popping functionality to use every feature? - AlecMataloni [more]
Unread 04-02-2010, 15:39
oddjob oddjob is offline
oddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to behold
I2C - Current Address Read
The I2C library Read() code is
Synchronized sync(m_semaphore);
m_module->m_fpgaDIO->writeI2CConfig_Address(m_deviceAddress, &status);
m_module->m_fpgaDIO->writeI2CConfig_BytesToWrite(sizeof(registerAddress), &status);
m_module->m_fpgaDIO->writeI2CConfig_BytesToRead(count, &status);
m_module->m_fpgaDIO->writeI2CDataToSend(registerAddress, &status);
UINT8 transaction = m_module->m_fpgaDIO->readI2CStatus_Transaction(&status);
m_module->m_fpgaDIO->strobeI2CStart(&status);
while(transaction == m_module->m_fpgaDIO->readI2CStatus_Transaction(&status)) taskDelay(1);
while(!m_module->m_fpgaDIO->readI2CStatus_Done(&status)) taskDelay(1);
data = m_module->m_fpgaDIO->readI2CDataReceived(&status);
I'm not sure, but that appears to be a I2C Random Address Read protocol.
Does anyone have I2C code for Current Address Read?
Start -> Address|1 -> Ack -> Data -> No Ack -> Stop
Unread 05-02-2010, 01:20
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: I2C - Current Address Read
The current implementation will read "count" bytes without reinitializing.
So you want to read without sending the register address? If that is what you mean, you should be able to simply use the new "Transaction" entry-point in the I2C class and pass 0 for the sendSize. This was added in the update that came out today.
-Joe
Unread 05-02-2010, 06:06
As usual, you are one step ahead. Thanks.
EDIT - any idea if/when the new sources will be posted at firstforge?
Unread 05-02-2010, 11:47
They have been since yesterday... in SVN anyway.
Unread 05-02-2010, 11:57
I was looking at the snapshot area, and the new source zip file didn't make it to there yet.
snapshot
EDIT - there is a new release there, but it looks like it is the update patch, not the source zip file.
Unread 05-02-2010, 11:58
snapshot
There now.
Unread 05-02-2010, 12:01
Whoops... just put up the team update... not the source... just a few more minutes.
Unread 05-02-2010, 14:31
Sorry for the confusion... the source is now posted as a snapshot.
ADXL345 using I2C tdidi C/C++ 1 29-01-2010 21:02
i2c output virtuald Programming 16 18-01-2009 19:20
what I2C means? matanost General Forum 6 11-12-2008 16:44
I2C tutorials John Gutmann Electrical 3 30-07-2005 10:44
I2C? John Gutmann Electrical 3 19-07-2005 22:52
