Go to Post Magic doesn't count as a support, sorry. Neither does simply constraining in CAD... - EricH [more]
Unread 04-02-2010, 21:35
tanguma26 tanguma26 is offline
FRC #3999
tanguma26 is an unknown quantity at this point
Unhappy Cylinders slow
We have try using the cylinders to kick the balls but everytime we try the cylinder releases really slow can any one help us to creat a mechanism using a cylinder that can be fast enoght to kick the ball with power and is fast.
Thank you
Unread 04-02-2010, 22:35
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Cylinders slow
Do you know what the Bore (Circumference of the cylinder) is on your Cylinder, and what its Stroke (How long your Cylinder extends to?) is?
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 04-02-2010, 23:24
billfunk29 billfunk29 is offline
FRC #3042 (Constant)
billfunk29 is an unknown quantity at this point
Re: Cylinders slow
I've elsewhre on the site that you can mechanically latch the cylinder so it will only extand 1/3 of the way. Then cycle the valve to pressurize the cylinder. Once the cylinder is up to pressure, release the latch. This gets around the flow restriction of the valves. Good luck.
Unread 05-02-2010, 02:12
dtengineering's Avatar
AKA: Jason Brett
Re: Cylinders slow
You'll likely find this thread interesting http://www.chiefdelphi.com/forums/sh...faster+release
Jason
Slow Site .. Brandon Martus Announcements 16 09-01-2006 10:27
Site Slow.. Brandon Martus Announcements 9 22-02-2005 21:07
How slow is too slow? Joe Ross Rules/Strategy 23 12-10-2004 20:23
Slow day? Josh Hambright Chit-Chat 6 06-04-2003 00:28
really slow........................... archiver 2001 5 24-06-2002 00:48
