Go to Post When is comes down to it, remember what FIRST is really about, it is about those students and helping to inspire them - E3 Robotics Ctr [more]
Unread 05-02-2010, 02:40
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Analog Input tied to Accelerometer on Cypress
Originally Posted by offramp13 View Post
The 8 analog ports displayed on the FRC Driver Station in advanced mode fluctuate with acceleration in the Z axis.
I am not sure if this is a configuration problem or if it is a problem with the hex code itself. Has anyone run into something similar to this?
Yes. I've run into this. Although it's not anything to "run into", per se. Because the inputs are high impedance, if you have no source wired to an input, then the previous input voltage will still be lingering around in the sample and hold capacitor. Because the accelerometer and the analog inputs are on the same analox mux, you will see the last channel of the accelerometer (Z) on the analog inputs.
Nothing to worry about.
-Joe
Analog Input Errors... Tach'ko Electrical 1 11-01-2008 11:37
HELP: analog input Tottanka Programming 19 18-02-2007 19:27
Accelerometer: Analog or Digital? psquared Programming 2 10-02-2005 16:38
Accelerometer Wiring/Input DAN THE MAN Control System 1 06-02-2005 20:02
Analog Input Trouble Matt Krass Programming 10 20-01-2005 21:09
