Go to Post I urge teams to look beyond what you are given in the kit of parts and strive for more - sanddrag [more]
Unread 05-02-2010, 08:18
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
Re: NetBeans not talking to the cRio
We have the same problem, Netbeans do not continue to working. We have the latest updates but we can not load or run our program through NetBeans.
We need help, please!!!
Unread 05-02-2010, 12:00
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
Please post the run output.
Unread 05-02-2010, 15:08
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
Besides setting the update URL you also need to keep an eye out for new updates and select the Updates tab, and press 'Update'. Here is an attachment of what it looks like for NetBeans updates, my FRC is up to date so I couldn't show that.
Unread 05-02-2010, 21:41
SGK's Avatar
SGK SGK is offline
None #0175 (BUZZ Robotics)
Team Role: Photography
SGK is just really niceSGK is just really niceSGK is just really niceSGK is just really niceSGK is just really nice
We just started having problems with our JAVA to the cRIO ever since NetBeans AutoUpdater updated and then 2 FRC plugins got upgraded too. One of them was FRCSquak which was upgraded from 1.15 to 1.17. Getting "Feed Watchdog" Error oscilating on Dashboard. Plugged in a machine w/o the upgrade and no issues.
Anybody got a solution? Who needs to go back and check these plugins?
Unread 06-02-2010, 15:37
bsudduth bsudduth is offline
None #2751
bsudduth is an unknown quantity at this point
We had this problem immediately after we updated the cRIO to v19 and used the latest FRC Plugin updates. We set the NoApp DIP Switch on the cRIO to on and redeployed and it started working.
Hope this helps and was not a coincidence.
Unread 07-02-2010, 14:04
FRC #2905
@DerekWhite :
We found our problem we just forgot to update crio to v19 sorry about that. I think it is fixed now. But after installing the v19 a watchdog problem occured. We now try bsudduth's solution. I will send our feedback again.
Unread 07-02-2010, 14:19
FRC #2905
Here is the situation:
We are trying to use our joysticks and jaguars.Serial port was only a try, you can ignore it if you want.
Our java code:
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.GenericHID.Hand;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.Watchdog;
import edu.wpi.first.wpilibj.SerialPort;
import edu.wpi.first.wpilibj.visa.VisaException;
import edu.wpi.first.wpilibj.RobotBase;
public class RobotTemplate extends SimpleRobot {
    RobotDrive drive = new RobotDrive(1,2);
    final int baud = 9600;
    final int dataBits =8;
    SerialPort sp;
    Watchdog wd;
    public void autonomous() {
   System.out.println("autonomous OK");
        wd.feed();
    wd.setEnabled(false);
        drive.tankDrive(2, 2);
    public void operatorControl() {
        System.out.println("Operator OK");
        wd.feed();
        try
        sp = new SerialPort(baud,dataBits);
        catch(VisaException vs)
        Joystick driveJoy= new Joystick(1);
        Jaguar leftControl = new Jaguar(1);
        Jaguar rightControl = new Jaguar(2);
        if(driveJoy.getTrigger())
            leftControl.set(driveJoy.getY());
            rightControl.set(driveJoy.getAxis(Joystick.AxisType.kX));
        else if(driveJoy.getRawButton(2))
            leftControl.set(driveJoy.getThrottle());
            rightControl.set(driveJoy.getAxis(Joystick.AxisType.kThrottle));
        else if(driveJoy.getRawButton(4))
            leftControl.set(driveJoy.getMagnitude());
And here is the console output:
init:
init:
No to.jar.file specified.
Using "suite\RobotTemplate_1.0.0.jar"
Deleting directory C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\build
Deleting directory C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\suite
Deleting directory C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\j2meclasses
clean:
Created dir: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\build
Compiling 1 source file to C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\build
compile:
Created dir: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\j2meclasses
preverify:
Created dir: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\suite
Building jar: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\suite\RobotTemplate_1.0.0.jar
jar-app:
CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes
CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt
CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods
[translating suite image [closed: false, parent: squawk] ...]
### Excluding compile: com.sun.squawk.Method::getParameterTypes
### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt
Romizer processed 77 classes and generated these files:
  C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\image.sym
  C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\image.suite
  C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\image.suite.metadata
  C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\image.suite.api
Expanding: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\suite\RobotTemplate_1.0.0.jar into C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\suite
Moving 1 file to C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\suite
Deleting: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\image.suite.api
Connecting FTP @10.29.5.2
upgrade:
Sending local file image.suite
flashapp:
deploy:
init:
[cRIO] [OTA Server] ********* REBOOTING cRIO *********
[cRIO]
   Waiting for cRIO to reboot (1s)
   Waiting for cRIO to reboot (2s)
   Waiting for cRIO to reboot (3s)
   Waiting for cRIO to reboot (4s)
   Waiting for cRIO to reboot (5s)
   Waiting for cRIO to reboot (6s)
   Waiting for cRIO to reboot (7s)
[cRIO]
[cRIO] -> * Loading StartupDlls: debug
[cRIO] Entering debug.o StartupLibraryInit
[cRIO] Debugging is up, target server mounted at /tsfs
[cRIO]
[cRIO]
[cRIO]                 VxWorks
[cRIO]
[cRIO] Copyright 1984-2006  Wind River Systems, Inc.
[cRIO]
[cRIO]              CPU: MPC5200 -- Wind River Lite5200 BSP.
[cRIO]     Runtime Name: VxWorks
[cRIO]  Runtime Version: 6.3
[cRIO]      BSP version: 2.0/10
[cRIO]          Created: Jul 29 2009, 13:41:47
[cRIO] ED&R Policy Mode: Deployed
[cRIO]    WDB Comm Type: WDB_COMM_END
[cRIO]              WDB: Ready.
[cRIO]
[cRIO] Leaving debug.o StartupLibraryInit
[cRIO] * Loading StartupDlls: NiRioRpc
[cRIO] * Loading StartupDlls: niorbs
[cRIO] * Loading StartupDlls: NiViSrvr
[cRIO] * Loading StartupDlls: nivissvc
[cRIO] task 0xee3da8 (PAL00fb5148) deleted: errno=0 (0) status=0 (0)
[cRIO] NI-RIO Server 3.2 started successfully.
[cRIO] task 0xc5f1f8 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
[cRIO] * Loading StartupDlls: nivision
[cRIO] * Loading StartupDlls: niserial
[cRIO] * Loading StartupDlls: FRC_FPGA
[cRIO] * Loading StartupDlls: FRC_NetworkCommunication
[cRIO] FRC_NetworkCommunication was compiled from SVN revision 2064
[cRIO] FPGA Hardware GUID: 0xAD9A5591CC64E4DF756D77D1B57A549E
[cRIO] FPGA Software GUID: 0xAD9A5591CC64E4DF756D77D1B57A549E
[cRIO] FPGA Hardware Version: 2010
[cRIO] FPGA Software Version: 2010
[cRIO] FPGA Hardware Revision: 1.3.0
[cRIO] FPGA Software Revision: 1.3.0
[cRIO] * Loading StartupDlls: FRC_JavaVM
[cRIO]
[cRIO]
[cRIO] [OTA Server] Version: 2010 FRC, Feb  4 2010, 21:33:36
[cRIO]
[cRIO] task 0x214b2d0 (t2) deleted: errno=0 (0) status=0 (0)
[cRIO]
[cRIO] Welcome to LabVIEW Real-Time 8.6.1f2
[cRIO]
[cRIO] NI-VISA Server 4.5 started successfully.
[cRIO] task 0xe623d0 (t1) deleted: errno=1835009 (0x1c0001) status=1 (0x1)
[cRIO]
[cRIO] [Squawk VM] Version: 2010 FRC, Feb  4 2010, 21:35:40
[cRIO] FPGA Hardware GUID: 0xad9a5591cc64e4df756d77d1b57a549e
[cRIO] FPGA Software GUID: 0xad9a5591cc64e4df756d77d1b57a549e
[cRIO] Information: No user-supplied robotMain()
[cRIO] task 0xe5f610 (FTP Server Connection Thread) deleted: errno=70 (0x46) status=0 (0)
[cRIO] Operator OK
[cRIO] java.lang.NullPointerException
[cRIO]     at java.lang.Throwable.<init>(Throwable.java:88)
[cRIO]     at java.lang.Exception.<init>(Exception.java:44)
[cRIO]     at java.lang.RuntimeException.<init>(RuntimeException.java:48)
[cRIO]     at java.lang.NullPointerException.<init>(NullPointerException.java:54)
[cRIO]     at com.sun.squawk.VM.nullPointerException(VM.java:391)
[cRIO]     at edu.wpi.first.wpilibj.templates.RobotTemplate.operatorControl(RobotTemplate.java:57)
[cRIO]     at edu.wpi.first.wpilibj.SimpleRobot.startCompetition(SimpleRobot.java:83)
[cRIO]     at edu.wpi.first.wpilibj.RobotBase.startApp(RobotBase.java:132)
[cRIO]     at javax.microedition.midlet.MIDletTunnelImpl.callStartApp(MIDletTunnelImpl.java:60)
[cRIO]     at com.sun.squawk.imp.MIDletMainWrapper.main(MIDletMainWrapper.java:110)
[cRIO]     at com.sun.squawk.Klass.main(Klass.java:2997)
[cRIO]     at com.sun.squawk.Isolate.run(Isolate.java:1554)
[cRIO]     at java.lang.Thread.run(Thread.java:231)
[cRIO]     at com.sun.squawk.VMThread.callRun(VMThread.java:1499)
[cRIO]     at com.sun.squawk.VM.callRun(VM.java:305)
The driver sitation do not permit me to control both teleoperated and autonomous control. When i press enable the clock starts but stops after 3 seconds. Than it says "Teleoperated/Autonomous Disabled" and "Watchdog Not Fed".
Is the problem about my code? What should i do?
Downloading code: Netbeans does not reset cRIO ellisk Java 8 31-01-2010 19:02
Laptop is not finding the cRIO properly? Studentish Electrical 4 07-05-2009 12:03
Reimaging the cRio Issues there are no cRio devices on the subnet Stuart FRC Control System 2 25-02-2009 23:41
Heres a big problem that I think Discreet does not know what they are talking about. wes16zeus 3D Animation and Competition 9 09-01-2002 23:31
