Go to Post Please Note: Elgin is still wearing his safety glasses. Practice safe Dewing. - JohnBoucher [more]
Unread 05-02-2010, 11:25
WarrenPW WarrenPW is offline
FRC #2085
WarrenPW is an unknown quantity at this point
cRIO Startup code corrupts on boot, reformatting doesn't help.
Hello,
This week we have been having trouble with the cRIO in two different ways. First of all, the cRIO somehow managed to set itself to get an address via DHCP, and though multiple reformats didn't help, we were able to fix this with the MAX Measurement and Automation Explorer, but now when we try to boot the cRIO with deployed code, the robot reboots a couple of times, and then the status light blinks four times every second. MAX says that the error is that the cRIO had rebooted to many times and had been put into safe mode because of a corrupt startup program, but the code looks fine in Labview, and when we load the default code from a new project, the same thing happens. Is it possible that more than the TCP/IP settings got changed in the cRIO?
Team 2085 Robodogs
Unread 05-02-2010, 12:20
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
Re: cRIO Startup code corrupts on boot, reformatting doesn't help.
WarrenP,
Saw your post and know how frustrating it can be to wait for an answer and so wanted to help so I went searching for you. I found this post in the FIRST forums. This has the contact information for National Instruments. I would get in touch with them ASAP to try and figure out what's going on...
Good Luck!
Originally Posted by NI-Bob View Post
Hello Quattda,
I am sorry for the confusion here. After doing some searching I was able to find your post. The reason that you did not get a response is because you actually posted on the LabVIEW forums and not on the FIRST Specific forums.
You can find the NI FIRST Forums on www.ni.com/first (there are tabs towards the top of the page and one of the tabs is Discussions). We will be very happy to answer any questions from there.
Also, just so you know we have phone support from 1:00pm to 7:00pm Central Time. To get in touch with us you can call (866) 511-6285.
In regards to the issue that you are running into, LabVIEW FRC 2010 is not supported on Windows 64 bit. It may work and it may not but it was never officially tested for Windows 64 bit. The one piece of advice that I have is to make sure that you are installing it as a 32-bit application but beyond that unfortunately I do not have any other suggestions. Another option is that you could use the Intel Classmate to program as it has the development software installed on it. I know the keyboard is a little on the small side but all you have to do is run the Mandatory Updates for LabVIEW and the Driver Station and you are ready to go.
Please let me know if there is anything else that I can do for you and feel free to contact National Instruments in the future either on the NI FIRST Forums or through FIRST Phone Support and we will be very happy to assist you. I hope this helps!
Thanks!
Bob
NI FIRST Support
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 06-02-2010, 00:35
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Please check that all the DIP switches on the cRIO are in the OFF position.
(page 12 of the cRIO-FRC operating instructions)
It may not be the case, but it's the only thing I could think of other than the cRIO having a manufacturing flaw.
-- Marshal Horn
Unread 06-02-2010, 12:33
FRC #2085
Thank you guys! You are both alot of help!
I will make a new post on the LabView forums and hopefully post an answer shortly!
Unread 09-02-2010, 19:39
FRC #2085
Thumbs up Re: cRIO Startup code corrupts on boot, reformatting doesn't help.
Thanks again for the help! We contacted NI and found out that we needed to use MAX instead of the imaging tool AND that the cRIO had to be in safe mode first, along with the fact a new update had been released.
WarrenPW
Team 2085
cRio doesn't re-image Lilszamora FRC Control System 3 15-02-2009 21:06
changing code after it's set to run at startup smcmahon NI LabVIEW 4 11-02-2009 19:36
cRio losing connection when "run as startup" mgurgol Programming 2 12-01-2009 12:18
confused, some startup help... NetSkay Programming 1 31-10-2008 21:44
Reformatting Raven_Writer IT / Communications 27 16-07-2004 19:10
