Go to Post Crushing the box makes it much easier to think outside the box. :D - Matt C [more]
Unread 05-02-2010, 11:46
lscime lscime is offline
AKA: Luke Scime
FRC #2614 (Mountaineer Area RoboticS (MARS))
lscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to behold
Re: jaguar speed control of mecanum wheels
As far as I know the PWM signals only tell the Jaguar to adjust it's output voltage, there is no feedback from the motors to the Jaguars. I do believe that you can wire say a limit switch directly to the Jaguar to make it stop or start (or brake or coast) but I know of no way to hook an optical encoder-type device to the Jaguar directly.
We are using Holonomic Mecanum drive this year and it functions fine without using a PID loop to adjust the wheel speeds (although we did that last year for traction-control ).
Good Luck!
Unread 05-02-2010, 12:32
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
The servo signal input to the Jaguar controls the voltage output. There isn't built-in closed-loop control when using the servo signal input.
You can definitely connect an optical encoder to the Jaguar. Please see the Getting Started Guide at www.luminarymicro.com/jaguar for an overview on all the possible control modes that the Jaguar supports.
You can connect encoders, limit switches, and/or analog potentiometers (or other analog signals) to the Jaguar inputs. Using CAN, you can change the mode to control voltage, speed, position (like a hobby servo, for example, imagine a CIM motor that holds position like a servo!), and current and then change parameters for P, I, and D so that the Jaguar does all the closed-loop control for you.
-David
Unread 05-02-2010, 12:43
Good Luck!
Hi lscime,
Thanks for sharing your experience with mecanum without closed-loop control of drive wheels. I think that's what we are going to settle for this year because giving our brand-new software guys another task would be too much at this point I think.
Setting the speed on a jaguar in C++ DillonMartine Programming 3 01-02-2009 11:26
pic: Jaguar Speed Controller Padre_Vez Extra Discussion 15 31-01-2009 14:41
Mecanum Wheels tennispro9911 Technical Discussion 6 07-11-2008 00:04
Drive Control, Wheel Speed Calibration, and Rapid Speed Changes 7-11number1 Programming 3 23-01-2008 20:36
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
