Go to Post "How do we make our team be like your team?" That's the sort of question everyone should be asking of these so-called "elite" or "powerhouse" teams. - sanddrag [more]
Unread 23-01-2010, 05:48
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: new festo valves
Originally Posted by jsasaki View Post
Im sorry but im not exactly getting this but from what i've been hearing/reading the pneumatic bumper is connected to the 24v source on the distribution board (2 left over leads on the WAGO connector that connects the cRio to the Distribution board) and then the two ends of the solenoid being connected to the bumper right? So if this is right that means were gonna have to use 2010 and only the 2010 festo valves hence the 2008 and 2009 SMC and Festo valves are not going to have the right amount of voltage thus not working right???? This years pneumatics are complicated we should have sticked with the old SMC and Festo solenoid
thanks for you help
That is correct, you could only power the 2010 Kit solenoid valve off of the 24V Solenoid Breakout (or any purchased 24V solenoid valves that meets the requirements of the rules).
You can use an additional Solenoid Breakout board connected to a 20A breaker to power 12V solenoids on the same robot. You could also use one or more Spike Relays to power 12V solenoids.
Unread 23-01-2010, 05:50
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
Thanks alot for you help !
Unread 23-01-2010, 08:10
Originally Posted by bhsrobotics1671 View Post
So are you still allowed to use the 2009 festos?
Thanks for the reminder, I neglected to address that point.
The 2009 and earlier KOP Festo solenoid is NOT legal for use on the robot this year.
They are commercially available (thanks Corey).
Unread 23-01-2010, 19:10
smevawala smevawala is offline
FRC #1257
smevawala is an unknown quantity at this point
Originally Posted by Mark McLeod View Post
By "other" Festo I assume you mean the 2009 KOP Festo?
That is NOT legal for use on the robot this year, because it must be commercially available (find someplace selling them-eBay doesn't count). Those were a special FIRST only edition.
2009 Festo Wiring
The 2 wires then go back to a 12v Solenoid Bumper or a Spike (Spike is then controlled by a PWM cable connected to a Digital Sidecar Relay.
Um R33, from my knowledge, says that the 2009 Festo valve is legal.
Originally Posted by FRC Manual
<R33> COTS items from ROBOTS entered in previous FIRST competitions or COTS items that are
no longer commercially available may be used under the following conditions:
A. The item must be functionally equivalent to the original condition as delivered from the
VENDOR (e.g. a part that has non-functional label markings added would be permitted,
but a part that has device-specific mounting holes added would be prohibited), and
B. The item must satisfy ALL applicable 2010 FRC materials/parts use rules.
Please tell me if I am correct or not.
Unread 23-01-2010, 20:35
Corey has found them commercially available and corrected my error.
I believe past Festo valves were not a COTS item, but custom-made for FIRST. At least as I understand it, they were a special production run specifically for FIRST and they couldn't be purchased anywhere but through the special Festo FIRST site. That would bring them under Rule <R34>. However, it's certainly something that we could get a ruling on in the Q&A. It's possible, since they were donated by Festo, rather than contracted by FIRST, that FIRST treated the Festo valves as COTS.
I'll post the question to the Q&A.
<R34> Parts custom-made for FIRST and provided to FRC teams in the Kit Of Parts for previous FRC competitions (e.g. 2006 FRC transmissions, custom-made motor couplers, custom sensor strips, FRC CMUcam II modules, etc.) may be used if the part is still functionally equivalent to the original condition and:
A. The part is now generally available as a COTS item from an accessible source, or
B. All information required to fabricate the part (e.g. complete drawings, materials list, Gerber Files where appropriate, etc.) is openly available, such that any team could fabricate the part (or have it fabricated for them).
Otherwise, such parts are prohibited from use in the 2010 competition.
Unread 23-01-2010, 20:41
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
I believe past Festo valves were not a COTS item, but custom-made for FIRST. At least as I understand it, they were a special production run specifically for FIRST. That would bring them under Rule <R34>. However, it's certainly something that we could get a ruling on in the Q&A. It's possible, since they were donated by Festo, that FIRST treated the Festo valves as COTS.
You can get the older festo "block style" ones from any festo distributor just give them the p/n 13026238 hands down COTS
http://www.pneuaire.com/13026238.html
Unread 23-01-2010, 21:17
I stand corrected.
If they are available, then there's no issue.
Thanks Corey.
Unread 30-01-2010, 15:17
GoldenAI's Avatar
GoldenAI GoldenAI is offline
AI + Gold = GoldenAI
AKA: Johnathan Lane
FRC #0558 (RoboSquad 558)
Team Role: Webmaster
GoldenAI will become famous soon enough
okay I know the 09 Festo's are legal (#13026238), but what about 08's?
Festo P/N #13026684. That would help us out a lot. I'm pretty sure that was implied, but I want clarification
GoldenAI
Unread 30-01-2010, 15:45
Team2340's Avatar
Team2340 Team2340 is offline
AKA: Jamey
FRC #2340 (Xcentrics)
Team Role: Electrical
Team2340 is an unknown quantity at this point
Thumbs up Re: new festo valves
ok, so i've looked over these posts over and over again and i don't want to sound stupid, but for some reason i'm not comprehending where you connect the solinoid valve, i understand that you connect it to the bumper on the cRio, but there are only two wires on the solinoid valve, where on the bumper, there are three prongs for signal, +, -. so i think that's where i'm getting confused and i'm totally new at even knowing what pneumatics are. I hope that once i figure out where to connect the valve, we will be all set, but i don't know.
Oh on the other hand, for the pressure switch... where does that get hooked up? or does it at all??
Sorry one last thing, is anyone using a pressure transducer?? if so what and how and where am i going to put that??
thanks so much
Thanks!! Team 2340 Xcentrics
Unread 30-01-2010, 16:14
Jones571's Avatar
AKA: Corey
FRC #0571 (Paragon)
Jamey,
check out this site they cover hooking up pneumatics very well.
http://www.team358.org/files/pneumatic/
Unread 31-01-2010, 09:04
Originally Posted by Team2340 View Post
... where you connect the solenoid valve, i understand that you connect it to the bumper on the cRio, but there are only two wires on the solenoid valve, where on the bumper, there are three prongs for signal, +, -.
I see the problem. There are two different types of Breakouts that connect to the cRIO Moduled that look very much alike. (2) Analog Breakouts and (1) Solenoid Breakout board.
  • The Breakout with 3-prongs is the Analog Breakout.
  • The Breakout with 2-prongs is the Solenoid Breakout.
The 2 wires from a solenoid connect to the two prongs on the Solenoid Breakout. The Solenoid Breakout gets attached to the cRIO Module that has the 8 tiny status lights on it. The cRIO Solenoid Module comes in slot 8.
The pressure switch gets wired to the signal and ground pins of Digital Input 1 on the Digital Sidecar. Do not use the power pin.
The switch itself gets attached to a fitting that allows it to be connected to the pneumatic tubing on the high pressure side.
The wiring for a pressure transducer goes to the Analog Bumper.
A pressure transducer gets attached to a brass pneumatic fitting so that it can be attached to the pneumatic tubing. Usually you want to have it on the high pressure side too. The same way the pressure switch is attached.
Unread 05-02-2010, 11:59
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
I stand corrected.
Thanks Corey.
They may be available, but how about Cv? Max Cv is .32, I have been unable to find published Cv. Above link relates Cv to Orifice size, but what is the orifice size of this valve?
Unread 05-02-2010, 12:18
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
I stand corrected.
Thanks Corey.
Mark,
Your link tries to relate orifice size to Cv. This is not a complete and accurate picture, and may only be good for one specific valve at a specific pressure. There are other factors that go into Cv such as orifice shape, Plunger shape, etc that need to be factored in.
___________________
- Tennyson, Ulysses
Unread 05-02-2010, 13:19
I asked Festo via email(product.support@us.festo.com) this was the response:
The Cv factor on the VPLE18 valve is Cv 0.297 at 80 psi.
If there are any other questions do not hesitate to contact me.
Best regards,
Robert
Unread 05-02-2010, 13:28
I wasn't trying to make any claims as regards Cv when I posted that link.
It was just the first one I could quickly find that included a photo of the valve, so we could see it had the same outward appearance as last year's model.
I don't believe the manufacturer was making any claims for other makers or even other models. They do list it as approximate Cv for this particular model. The orifice isn't the same as the port size if that's what you were thinking. A 1/8" orifice is what we got in past KOPs with an approximate Cv of .30 We can find the exact Cv (0.297) if we drill down into the product catalog.
In any case, FIRST 2010 Q&A has ruled the past Festo valve as legal for this year's competition.
New Festo valve 24v? IndySam Pneumatics 19 06-02-2010 16:31
How do I use the pneumatic Festo valves? mynameisbob Pneumatics 15 17-01-2009 18:10
2 FESTO valves on 1 spike bhsrobotics1671 Electrical 12 08-02-2008 13:37
Festo Valves 2 in manual but only 1 in KoP -- Clarification Needed Mentor 2660 Pneumatics 3 06-02-2008 14:55
Leaky Valves Mark Deutsch Pneumatics 9 16-02-2007 15:07
