#16
Re: NetBeans not talking to the cRio
We have the same problem, Netbeans do not continue to working. We have the latest updates but we can not load or run our program through NetBeans.
We need help, please!!! |
#17
Please post the run output.
#18
Besides setting the update URL you also need to keep an eye out for new updates and select the Updates tab, and press 'Update'. Here is an attachment of what it looks like for NetBeans updates, my FRC is up to date so I couldn't show that.
#19
We just started having problems with our JAVA to the cRIO ever since NetBeans AutoUpdater updated and then 2 FRC plugins got upgraded too. One of them was FRCSquak which was upgraded from 1.15 to 1.17. Getting "Feed Watchdog" Error oscilating on Dashboard. Plugged in a machine w/o the upgrade and no issues.
Anybody got a solution? Who needs to go back and check these plugins? |
#20
We had this problem immediately after we updated the cRIO to v19 and used the latest FRC Plugin updates. We set the NoApp DIP Switch on the cRIO to on and redeployed and it started working.
Hope this helps and was not a coincidence. |
#21
@DerekWhite :
We found our problem we just forgot to update crio to v19 sorry about that. I think it is fixed now. But after installing the v19 a watchdog problem occured. We now try bsudduth's solution. I will send our feedback again. |
#22
Here is the situation:
We are trying to use our joysticks and jaguars.Serial port was only a try, you can ignore it if you want. Our java code: Code:
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.GenericHID.Hand;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.Watchdog;
import edu.wpi.first.wpilibj.SerialPort;
import edu.wpi.first.wpilibj.visa.VisaException;
import edu.wpi.first.wpilibj.RobotBase;
public class RobotTemplate extends SimpleRobot {
RobotDrive drive = new RobotDrive(1,2);
final int baud = 9600;
final int dataBits =8;
SerialPort sp;
Watchdog wd;
public void autonomous() {
System.out.println("autonomous OK");
wd.feed();
wd.setEnabled(false);
drive.tankDrive(2, 2);
public void operatorControl() {
System.out.println("Operator OK");
wd.feed();
try
sp = new SerialPort(baud,dataBits);
catch(VisaException vs)
Joystick driveJoy= new Joystick(1);
Jaguar leftControl = new Jaguar(1);
Jaguar rightControl = new Jaguar(2);
if(driveJoy.getTrigger())
leftControl.set(driveJoy.getY());
rightControl.set(driveJoy.getAxis(Joystick.AxisType.kX));
else if(driveJoy.getRawButton(2))
leftControl.set(driveJoy.getThrottle());
rightControl.set(driveJoy.getAxis(Joystick.AxisType.kThrottle));
else if(driveJoy.getRawButton(4))
leftControl.set(driveJoy.getMagnitude());
And here is the console output: Code:
init: init: No to.jar.file specified. Using "suite\RobotTemplate_1.0.0.jar" Deleting directory C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\build Deleting directory C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\suite Deleting directory C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\j2meclasses clean: Created dir: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\build Compiling 1 source file to C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\build compile: Created dir: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\j2meclasses preverify: Created dir: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\suite Building jar: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\suite\RobotTemplate_1.0.0.jar jar-app: Using "suite\RobotTemplate_1.0.0.jar" CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods [translating suite image [closed: false, parent: squawk] ...] ### Excluding compile: com.sun.squawk.Method::getParameterTypes ### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt Romizer processed 77 classes and generated these files: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\image.sym C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\image.suite C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\image.suite.metadata C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\image.suite.api Expanding: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\suite\RobotTemplate_1.0.0.jar into C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\suite Moving 1 file to C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\suite Moving 1 file to C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\suite Moving 1 file to C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\suite Deleting: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\image.suite.api Connecting FTP @10.29.5.2 upgrade: Sending local file image.suite flashapp: deploy: init: [cRIO] [OTA Server] ********* REBOOTING cRIO ********* [cRIO] Waiting for cRIO to reboot (1s) Waiting for cRIO to reboot (2s) Waiting for cRIO to reboot (3s) Waiting for cRIO to reboot (4s) Waiting for cRIO to reboot (5s) Waiting for cRIO to reboot (6s) Waiting for cRIO to reboot (7s) [cRIO] [cRIO] -> * Loading StartupDlls: debug [cRIO] Entering debug.o StartupLibraryInit [cRIO] Debugging is up, target server mounted at /tsfs [cRIO] [cRIO] [cRIO] VxWorks [cRIO] [cRIO] Copyright 1984-2006 Wind River Systems, Inc. [cRIO] [cRIO] CPU: MPC5200 -- Wind River Lite5200 BSP. [cRIO] Runtime Name: VxWorks [cRIO] Runtime Version: 6.3 [cRIO] BSP version: 2.0/10 [cRIO] Created: Jul 29 2009, 13:41:47 [cRIO] ED&R Policy Mode: Deployed [cRIO] WDB Comm Type: WDB_COMM_END [cRIO] WDB: Ready. [cRIO] [cRIO] Leaving debug.o StartupLibraryInit [cRIO] * Loading StartupDlls: NiRioRpc [cRIO] * Loading StartupDlls: niorbs [cRIO] * Loading StartupDlls: NiViSrvr [cRIO] * Loading StartupDlls: nivissvc [cRIO] task 0xee3da8 (PAL00fb5148) deleted: errno=0 (0) status=0 (0) [cRIO] NI-RIO Server 3.2 started successfully. [cRIO] task 0xc5f1f8 (NiRioRpc) deleted: errno=0 (0) status=0 (0) [cRIO] * Loading StartupDlls: nivision [cRIO] * Loading StartupDlls: niserial [cRIO] * Loading StartupDlls: FRC_FPGA [cRIO] * Loading StartupDlls: FRC_NetworkCommunication [cRIO] FRC_NetworkCommunication was compiled from SVN revision 2064 [cRIO] FPGA Hardware GUID: 0xAD9A5591CC64E4DF756D77D1B57A549E [cRIO] FPGA Software GUID: 0xAD9A5591CC64E4DF756D77D1B57A549E [cRIO] FPGA Hardware Version: 2010 [cRIO] FPGA Software Version: 2010 [cRIO] FPGA Hardware Revision: 1.3.0 [cRIO] FPGA Software Revision: 1.3.0 [cRIO] * Loading StartupDlls: FRC_JavaVM [cRIO] [cRIO] [cRIO] [OTA Server] Version: 2010 FRC, Feb 4 2010, 21:33:36 [cRIO] [cRIO] task 0x214b2d0 (t2) deleted: errno=0 (0) status=0 (0) [cRIO] [cRIO] Welcome to LabVIEW Real-Time 8.6.1f2 [cRIO] [cRIO] NI-VISA Server 4.5 started successfully. [cRIO] task 0xe623d0 (t1) deleted: errno=1835009 (0x1c0001) status=1 (0x1) [cRIO] [cRIO] [Squawk VM] Version: 2010 FRC, Feb 4 2010, 21:35:40 [cRIO] FPGA Hardware GUID: 0xad9a5591cc64e4df756d77d1b57a549e [cRIO] FPGA Software GUID: 0xad9a5591cc64e4df756d77d1b57a549e [cRIO] Information: No user-supplied robotMain() [cRIO] task 0xe5f610 (FTP Server Connection Thread) deleted: errno=70 (0x46) status=0 (0) [cRIO] task 0xe5f610 (FTP Server Connection Thread) deleted: errno=70 (0x46) status=0 (0) [cRIO] Operator OK [cRIO] java.lang.NullPointerException [cRIO] at java.lang.Throwable.<init>(Throwable.java:88) [cRIO] at java.lang.Exception.<init>(Exception.java:44) [cRIO] at java.lang.RuntimeException.<init>(RuntimeException.java:48) [cRIO] at java.lang.NullPointerException.<init>(NullPointerException.java:54) [cRIO] at com.sun.squawk.VM.nullPointerException(VM.java:391) [cRIO] at edu.wpi.first.wpilibj.templates.RobotTemplate.operatorControl(RobotTemplate.java:57) [cRIO] at edu.wpi.first.wpilibj.SimpleRobot.startCompetition(SimpleRobot.java:83) [cRIO] at edu.wpi.first.wpilibj.RobotBase.startApp(RobotBase.java:132) [cRIO] at javax.microedition.midlet.MIDletTunnelImpl.callStartApp(MIDletTunnelImpl.java:60) [cRIO] at com.sun.squawk.imp.MIDletMainWrapper.main(MIDletMainWrapper.java:110) [cRIO] at com.sun.squawk.Klass.main(Klass.java:2997) [cRIO] at com.sun.squawk.Isolate.run(Isolate.java:1554) [cRIO] at java.lang.Thread.run(Thread.java:231) [cRIO] at com.sun.squawk.VMThread.callRun(VMThread.java:1499) [cRIO] at com.sun.squawk.VM.callRun(VM.java:305) Is the problem about my code? What should i do? |
| Downloading code: Netbeans does not reset cRIO | ellisk | Java | 8 | 31-01-2010 19:02 |
| Laptop is not finding the cRIO properly? | Studentish | Electrical | 4 | 07-05-2009 12:03 |
| Reimaging the cRio Issues there are no cRio devices on the subnet | Stuart | FRC Control System | 2 | 25-02-2009 23:41 |
| Heres a big problem that I think Discreet does not know what they are talking about. | wes16zeus | 3D Animation and Competition | 9 | 09-01-2002 23:31 |
