Go to Post I openly admitted to using IE at robotics last year and recieved a major lashing for such blasphemy. Then I downloaded Chrome. - jwallace15 [more]
Unread 05-02-2010, 12:11
Rapt0r9's Avatar
Rapt0r9 Rapt0r9 is offline
AKA: Tyler
FRC #0747 (Flight Crew)
Rapt0r9 will become famous soon enoughRapt0r9 will become famous soon enough
Default Code Functionality
Its been a while since I've been on CD, but here we go.
I've been mentoring some students in using Labview, which I have also been learning. I have a basic understanding of how to implement different functions and interact with different devices through the default framework. We've implemented tank drive and have started on coding the mechanisms.
My question is, what is the default functionality of the framework? What I mean by this is, what are features that are implemented by default and how dose joystick 1 call them.
I understand the vi structure and have already worked with the axises on the joysticks for the drive routine, I just am unsure what the buttons do and don't want to create conflicts while programming them.
Thanks.
BS Information Technology - NJIT (2009 - )
Team 869 (2004 - 2008, 2011 -), Team 1811 (2010), Team 869 (2009), Team 613 (2009 - 2010)
"Nothing in this life worth having comes easy."
Unread 05-02-2010, 12:36
Re: Default Code Functionality
The Teleop block diagram contains a comment that claims that Button 2 resets the gyro. The Joystick Read subVI disagrees, and when the code and the comments disagree, the code wins.
The USB device named Joystick 1 controls everything. Its X and Y axes feed Arcade Drive.
Button 3 activates the auto-aim code. When it is first pressed, the camera targeting information is used to determine a desired turn angle. While it is still pressed, a PID routine uses gyro feedback to control Arcade Drive and spin the robot to the target.
Buttons 8 and 9 together reset the gyro.
Unread 05-02-2010, 12:41
Rapt0r9's Avatar
AKA: Tyler
That's exactly what I needed, thanks.
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
Math functionality in EasyC? scottmso Programming 7 16-02-2006 14:52
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
user code to default code phoenixomega001 Programming 5 09-01-2005 00:09
