Go to Post It would be wise to consider the reasoning behind the statement rather than the statement itself. Sometimes they are right... other times their statement is incomplete... and other times they really do have no clue what they are talking about. - dtengineering [more]
Unread 05-02-2010, 12:57
M-Ross M-Ross is offline
FRC #2909
M-Ross is an unknown quantity at this point
joystick reference numbers
We put a program into our robot, and only one side of our drive system is working. The other joystick is not running the other side as it should.
I think the problem may be that I did not differentiate between mutliple joystick reference VIs. Can you use multiple ones? How does labview tell them apart when I "get" them in another place?
Thanks!
Unread 05-02-2010, 13:09
Re: joystick reference numbers
Use the same text name as input to the RefNum Registry Set and Get vi's. Use two different names for the two different joysticks.
The Joystick Read SubVI only uses Joystick 1. You can change it to return references to both joysticks if you like, though that's a little cumbersome unless you're already familiar with how to work with SubVIs. It would probably be easier to ignore it and just use a Joystick Get for each of the two joysticks.
relay device reference? finman Programming 5 10-02-2009 17:59
cim reference table bensamra34 Technical Discussion 0 16-01-2008 19:57
Fastener reference Dick Linn Technical Discussion 12 17-06-2007 16:05
ME reference manual Gdeaver Technical Discussion 10 06-12-2005 12:42
reference manuals sciguy125 Career 11 05-09-2005 12:31
