Go to Post Why climb up to the scaling rungs when you can move the entire field down to your robot's height? - marcusbernstein [more]
Unread 05-02-2010, 15:11
robotic321's Avatar
robotic321 robotic321 is offline
FRC #1793
robotic321 is an unknown quantity at this point
Unhappy Trouble setting up 4 motors.
I been trying to adjust the Defualt Code trying to get 4 motors set up so i can get holonomic drive working, but its not finding all 4 motors. What do i need to do to get it set up for 4 motors?
Unread 05-02-2010, 15:23
Re: Trouble setting up 4 motors.
In Begin.vi, simply replace the Open 2 Motor Drive vi with Open 4 Motor Drive, then add the appropriate PWM channels (and optional "invert" selections) for the additional two motors.
Unread 05-02-2010, 15:38
robotic321's Avatar
FRC #1793
Yep that worked, thanks for the help!
trouble setting IP addresses... pinballwizard96 FRC Control System 4 20-01-2009 22:42
Trouble setting team number in OS Gene F National Instruments LabVIEW and Data Acquisition 4 08-12-2008 08:26
Setting Up... jumpe1990 Regional Competitions 3 18-03-2008 17:16
Inventor software trouble/ FIRST Base trouble nasa-senpai General Forum 2 24-01-2007 09:15
