Go to Post Whether or not you use wheel weights, if you're running a wheel at several thousand RPM, you'd better have an effective containment system to protect the outside world in case something spontaneously disassembles itself. - Alan Anderson [more]
Unread 01-02-2010, 11:28
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Re: New Camera Class
The GDC got back to us, and their answer is, in a word, no:
http://forums.usfirst.org/showthread.php?t=14284
We'll have to see what this update brings before moving forward.
Unread 01-02-2010, 12:17
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
It looks like what they really said is no to UDP... can you make it work over TCP?
Unread 01-02-2010, 14:14
slavik262's Avatar
AKA: Matt Kline
Sure, but we think that a lot of the slowness was caused by TCP. For example, if a frame of the video being transmitted gets screwed up, it's not that big of a deal using UDP, especially if you have a high framerate. You can just drop the frame and wait for the next one (no big deal if you're getting a good 20 of them every second - the user will barely notice). If we use TCP and the same thing happens to a packet, the receive() function stops the entire program execution, sends a request to resend the packet, and waits for the packet to get sent again, all for just one frame (or even just one part of a frame). You're making the entire system, which could be better spending its time just displaying the next frame(s), wait on just one frame instead of moving on.
We're also aware that some of the latency is being caused by the Classmate not being enough to keep up with the cRIO, but TCP doesn't help in this respect.
Unread 01-02-2010, 14:26
TheDominis TheDominis is offline
FRC #2152
TheDominis has a spectacular aura aboutTheDominis has a spectacular aura about
They said no to UDP on port 1180. This makes perfect sense as our packets would corrupt the driver station's packets. Currently, the video server works off of port 1234 (25FPS@160x120 resized to 640x480). However, I see a lot of erroneous packets as the robot gets farther away.
TCP hates not being acknowledged...
The GDC does not mention that UDP couldn't be used on another port. They do mention custom TCP protocols are allowed, but not UDP. They do not mention no UDP for all ports or just 1180.
Unread 01-02-2010, 14:36
slavik262's Avatar
AKA: Matt Kline
We'd need to have clearance to use a port though, because the FMS firewalls off any ports not cleared for use by the robot and driver station.
Also, the video feed and the rest of the driver station data run on different ports. The video uses a TCP connection to port 1180, while the rest of the dashboard data sends 1018 byte packets through UDP on port 1165. They wouldn't corrupt each other at all.
I'll have to post the whitepaper I made about the rest of the dashboard data some time.
Unread 01-02-2010, 14:40
You should ask for official clarification on this, but my understanding is that UDP is not provisioned on any port on the FMS except for the official control and status packets, and you certainly can't use those.
Unread 01-02-2010, 14:41
That would be great!
Unread 01-02-2010, 15:37
I believe you (or someone else) mentioned sending video over the UserData dashboard data mechanism last year... it is implemented as UDP transfers, and only marginally smaller packets that you get with raw datagrams. I'm not aware of any changes that would have made this stop working. Is this method no longer feasible or desirable for some reason? This method has about 47kBytes/s throughput.
-Joe
Unread 01-02-2010, 16:56
FRC #2152
-Joe
Our team implemented this last year. We were trying to get a good video stream this year at high FPS with good quality. Each frame at 0 compression takes 5 packets. That's 10 FPS . We did something high around 70-80 and got 16 FPS, but the quality couldn't be used for image tracking.
The stream uses 100KB/s at 160x120 and we resize it to 640x480. It looks good actually.
Unread 01-02-2010, 17:01
slavik262's Avatar
AKA: Matt Kline
-Joe
We could definitely try using the user data to send video; the obvious drawback is it leaves less room for other data. From the testing my team has done with the user data stream, the data it sends is often redundant, so the actual useful bytes/second value is lower than the potential.
Unread 01-02-2010, 17:05
I only see redundant data sent if the user data is updated by a task that is not synchronized with the control packets.
Unread 02-02-2010, 08:37
slavik262's Avatar
AKA: Matt Kline
We'll have to check it out. Right now we're putting this project on the backburner for a week or so until this supposed update comes out.
Unread 05-02-2010, 15:49
Have you tried out the new update yet?
Unread 05-02-2010, 18:13
FRC #2152
I get about 150-250ms delay on the new camera.
Unread 05-02-2010, 21:00
Is that something that you are happy with? It seems to be a lot better than you were getting before. How about frame rate?
Also, if you look at the code and have any suggestions for improvement, please let me know.
Joe
define a new class(C++) nadavsen2 C/C++ 15 02-11-2010 13:21
Camera using IterativeRobot class Steve Warner C/C++ 2 24-01-2010 21:47
New class for Logitech Dual Action Gamepad Mike Soukup C/C++ 8 11-02-2009 20:08
Camera Help (New to Camera Programming) Idaman323 Programming 6 14-01-2006 03:56
**FIRST EMAIL**/FIRST Announces New Class of Senior Mentors. Billfred FIRST E-Mail Blast Archive 1 23-12-2004 13:32
